Freestanding stove in Existing fireplace
CabinDweller430
3
Pennsylvania
Looking for feedback on my situation, ideas on options, and opinion on feasibility of doing this by ourselves.
We currently have gas logs in what was originally a wood burning fireplace, an early 80s? Steel “Heatform.” The chimney runs directly through the center of our 2 story log home.
We would like to get a high btu wood stove to supplement the oil heated boiler system.
I was quoted $3,600 for a wood burning insert, $2,000 in materials, and $2,000 in labor. (Insulated liner, modification to existing firebox..)
A quick check on Facebook marketplace and there’s a handful of used stoves, freestanding and inserts, for under $1000.
It looks like I can get all of the liner parts etc, for under $2,000.
Do the labor ourselves and we can save $2,000 making the whole upgrade 50-60% cheaper.
Questions:
1.) Do I simply cut two of the heatform tubes and a few inches of the box to pull the liner in to the stove? (See Picture with red X’s at cuts)
2.) assuming the height works out, Is there any reason I can’t go buy this (or another) used Russo GV-30C (rear vent) for $500 and put it halfway on the hearth and half inside of the fireplace? (Attached fb listing)
How hard is it really to shove a 7-8”insulated flex liner down the chimney, throw a stove in the hole and fire it up? Nothing I have come across in my research has intimidated me yet, and certainly not versus spending thousands of dollars in labor.
  • [Hearth.com] Freestanding stove in Existing fireplace
I think the Russon GV-30C may be a side-loading catalytic stove. It probably needs a new cat. The stove would need to sit out on the hearth a bit for side loading. This may require a hearth extension. There is also the clearance to the wood mantel to be considered. I don't have the manual, but it's typically 84" from stove top.
The quoted price is not bad for a new insert + liner + install. What stove model was quoted?
I'd recommend sticking with 6" flue outlet stoves if the intent is DIY. Definitely measure the flue ID on this fireplace before going further.
Thanks for the response!
The $3600 model quoted was quadrafire expedition 2 insert. And I do have the option to finance that part if it came down to it.
I know that the Russo has side loading, but would I not be able to also front load? (I’ve never had a wood stove, so please tell me what I’m missing on that)
The used stove seller said the Russo’s rear outlet was 7” and that the Catlytic component was replaced last year
I still have to get on the roof to measure for my exact liner length and to confirm the flue width.
Most modern stoves take a 6" liner. A 7" liner is an oddball so it costs a lot more. The Russo has a large front door which can lead to smoke spillage when reloading via the front door., especially on a short, one story liner. They used to have a big andiron in front which also made front-loading hard. I'm not sure about this particular stove.
The Quad Expedition insert is what is called a single burn rate stove. You ignite the fire and let the stove take care of the rest. There is little user control over the fire. They are great for evening and weekend fires, but not so much for 24/7 heating. You can do better than the Quad Expendition depending on how the stove will be used. For example, if a Drolet Escape 1800i is ordered, it will be below $2000. Does the dealer sell other models like Regency, Pacific Energy, etc?
Regardless of insert choice, all will require fully seasoned firewood to perform properly. That is very hard to buy, especially at this time of year. Burning poorly seasoned wood will result in disappointing heat output, hard starts, and a dirty liner that needs frequent cleaning. It's best to avoid this is possible.
Great information. Fortunately I have a massive seasoned wood supply available to me, that’s the biggest reason for wanting to make the switch vs. the $1000 in oil and +400/mo electric expenses with thermostats at 65.
The local dealer carries Heat & Glo, QuadraFire, Harman, Kozy, and Vermont Castings. I don’t know that there is another dealer in the area.. what about online like this entire package?
The Drolet package deal can be a good one, IF it fits the needs of this particular installation. However, if this is a single-story install with a short flue and a flue tile that doesn't fit the top cap, then money will be wasted and kit doesn't include insulation. The chimney must be completely cleaned and inspected first. That should provide enough information to procede.
Looks like the dealer is a Forge & Flame shop. Most of those products fall under that label.
Reactions: CabinDweller430
I would strongly suggest an insulated liner with a short flue. I have a short flue with my Drolet 1800i and the insulated liner stayed very clean last year with no drafting issues.
I have both Jotul in the fireplace and an 1800i. Both are good. Both need blowers to heat well. If you like the look of the 1800i it is a solid stove. Anything over 20’ you might need a damper.
And there is a really big insert the blue ridge 500i. You didn’t mention your sq footage or insulation
