Hello,
I have a question for fellow Froling users. I have a Froling S3 Turbo 50 with two 300 gallon storage tanks. I have been running it for about 3 months and love the system. I do have a concern that has been addressed with the supplier. When the boiler is in "Off" mode and the boiler is 4 degrees higher than the top buffer tank temp the circ pump starts. When the tank temp is 3 degrees lower than the boiler the pumps turns off. This temperature fluctuates often boiler up or tank down 1 degree causing the pump to continually cycle on and off sometimes several time per minute. This does not seem to be good for the pump. Shouldn't there be a buffer when the pump cycles on it should remain on for a certain amount of time? Has anyone experienced this issue? If so is there a fix? If not a fix does anyone agree with the supplier that this is "the nature of the beast". Any comments or suggestions would be greatly appreciated. Thanks
![[Hearth.com] Froling pump short cycling [Hearth.com] Froling pump short cycling](https://www.hearth.com/talk/data/attachments/291/291363-4f6a1d96024f84a0dbe58cf120fa492e.jpg?hash=GsNCS3Fzp-)
