All,
I've been in my house for 7 years and have never really enjoyed my Heat-N-Glo 6000G-LP fireplace. It was installed in the house as new construction about 5 years before we moved in. I'm convinced something is not right with the setup, but I've been unable to get assistance from a local dealer/service company and I haven't been able to figure it out myself.
I have two issues with the fireplace: (1) low flame and (2) periodic flame-out.
When the air shutter is opened all the way, as it should be for a LP unit, the flame is blue and very low. I need to close the air shutter about 75% of the way to get a respectable semi-yellow flame with a bit of height. Even with the air shutter closed this far, the flame never pops up through the designer "hole" in one of the logs.
On occasion, after running the unit for a period of time (20-30 minutes), the flame just completely dies out. It does it slowly over time until it finally turns off. This doesn't happen all the time, it's very intermittent.
I brought the service company out again last year and they did the routine cleaning and told me "all is good". They said just leave the shutter partially closed if it works. Shortly after they left, the flame died.
Thermocouple and thermopile are good (both have been replaced a couple of times over the years by me). I have literally removed the whole unit, cleaned, and reassembled. There is a low-high knob on the unit that does nothing to the flame.
My knowledge of combustion tells me one of two things - it's either not getting enough fuel, or it's getting too much air. If the designated air shutter position for LP is to be fully open, and it has a low blue flame when this is the case, I'm assuming it's not getting enough fuel. I've disassembled and cleaned what I can, but I've not gone too deep in to the valve assembly to look for other problems.
It is labeled an LP fireplace, so I am assuming it has the right orifice and valve assembly installed. Ironically, when I had a new LP range installed a couple of years ago, they left it with NG settings and we were always wondering why it never worked well until I found that a part had to be reversed for LP.
Is it worth it to just order up a new LP orifice and new LP valve and just swap some parts out to see if it improves? Or any other thoughts?
First pic is flame with shutter wide open, second pic is flame with shutter about 75% closed.
Thanks!
Thanks!
