Gap in firebrick, cause for concern?
naehring2000
67
North Shore, MA
I bought an Englander 13 and as I was installing it I noticed a gap in the firebrick, I examined it and it appears the weld was a little fatter in that corner so the brick didn't quite fit like the one on the other side.
Should I fix this? I imagine that would create a hot spot.
[Hearth.com] Gap in firebrick, cause for concern?
If that gap is on the floor of the stove I personally wouldn't be overly concerned about it. But it being a new stove, I would talk to the place where you bought it so they are aware of it and have them put it on record. Eventually that gap will be filled with ash and that will insulate it from the heat. If the weld is fatter than the others on the stove I would imagine that is why the brick was cut shorter.
The brick is actually the same size as the one on the other side, it was just pushed further under the vertical brick lining the wall so it would fit, so I could take a little bit off that 45 angle with my tile saw but if it isn't a concern than I won't.
Yes it's on the floor.
Ash will fill in the hole. That is the main purpose of a lower heat break in fire. You never want to fully remove all the ashes because of their insulating capabilities.
Excellent! Thanks for everyone's input!
