So, my dealer thinks that my door gasket needs to be replaced. On the latch side the gasket appears to have been "stretched" during manufacture. I've removed all of the washers and as long as I work the gasket with my fingers between loads it will pass the dollar bill test - barely! But, the gasket is almost completely flat and nearly even with the outside edges of the channel. On the hinge side where the two ends of the gasket come together they appear to have been "saturated" with the original cement and are hard/crusty. They also do not completely fill the channel and have a small space between the two ends.
At any rate, the dealer gave me a new gasket and a tube of the Rutland gasket cement - the black stuff. A co-worker that is also a wood burner said not to use that stuff because it dries very hard and is extremely difficult to remove later. He said to use the "red high temp. silicone". Looking at my gasket, it kind of looks like they may have used red stuff originally but w/o removal I can't tell.
Now, I just have to wait for the weather to warm up a little bit so I can shut the stove down for a day!
