Has anyone found a comprehensive long term review of all of the popular Gassification wood boilers ? I have talked to folks at Portage and Main, Alternative Heat Solutions and Econoburn and they all seem to think that they make the best boiler. I am looking for input from actual gassification unit owners. Inside installation, outside instillation, inside a wood shed, outside a wood shed. Storage, wood consumption ETC:
I am currently running a oil fired boiler with 3 zones of hydronic heat and 1 DHW plate exchanger. House is well insulated 2 story. On coldest of days with temp set at 72 boiler kicks on about twice an hour and runs for 10-15 minutes. Running .75 tip in Weil McLean boiler. Total capacity of system is around 150 gallons.
Looking to add a Wood boiler with additional storage tank with loop exchangers inside to add more volume of water for storage. Also want to run additional underground piping to 30x40 pole shed w/uninsulated concrete floor R19 walls and roof for supplemental heat.and a 27x24 minimally insulated garage for enough heat to keep stuff from freezing on really cold days only.
Would I be better off using separate storage tanks in all 3 locations due to limited storage space in the boiler room in the house. I only have room for (2) 250 gallon tanks or (4) 80 gallon water heater tanks.
I am handy at fabrication, wiring and sourcing stuff so finding what I need is not a problem. Also looking into the idea of using a gassifier to heat storage water inside a greenhouse on a tempering valve for fish tank water and floating troughs in aquaponic gardening setup in the future if anyone has put together a reliable setup for this type of application.
