It's time to get the gear to go hunt wood. I have a '98 explorer and will just be loading up the back with the rear seats down. I'm sure I need a tarp. Am I going to need to upgrade the suspension to carry green wood? I know it's heavy enough that my back won't take much more than whatever will fit in the back. Also, is there something that will cover the windows? Is it a good idea to cut a sheet of plywood to fit behind the front seat? Is there a nylon web or something I can put behind me?
Here's the specs
http://www.explorerforum.com/ntrprize/spec1998.htm
I need a chainsaw and safety gear. I don't know anything about chainsaws other than to keep it off my legs, and supposedly Stihl is a good manufacturer. There is a gas station within range that sells 100% dinosaur gas, so there's that. Who makes good chaps and helmets?
I have leather boots, but should I get steel toe? Years ago I had plastic toe caps that slipped over my shoes when I worked in a factory, would that do the job?
For limbing, should I just figure on using the chainsaw or should I pack in a chopper? I'm guessing I just want to use the chainsaw...
Thanks for any help!
Here's the specs
