Gilson screw-drive wood splitter: $150
HeatsTwice
596
Santa Rosa, California
Ran across this today. First time I ever saw a screw drive splitter. It probably has a very long cycle time. I couldn't even find refernce to this make in a google search:
(broken link removed to http://sfbay.craigslist.org/nby/grd/3171119575.html)
Older Gilson screw-drive wood splitter. B & S motor, though can't tell what the horsepower is. Guessing 8+ HP based on the size. Ran well 7-8 years ago when I had a friend go through the motor and get it running. Hasn't been used since. Has been stored outside, though the motor has always been covered. Uses 1 7/8" ball and one tire has small leak. $150 firm.
  • [Hearth.com] Gilson screw-drive wood splitter: $150
yeah, that baby there is probably really slow. Not sure, I honestly have never seen one before.
You could probably put on a piece of wood to split, go cook dinner and come back and take it off.......
Reactions: Backwoods Savage
I'd be curious to see that thing work. I'm guessing slow as well, but it might be neat to run once. A C
Actually it could possibly be just as fast or faster than a hydraulic. The adjustable stroke and auto-return intrigue me and Gilson was not known for making junk back in the day. (Though I bet this machine was built when I was wettin' Huggies...) For $150 I'd have to give it a shot.....
Hell, if it turned out to be a turd it's a prime candidate for conversion to hydraulic power. For $150 it's got tires, a beam and a wedge already. Oh yeah, there's a sweet old-school Briggs on it too....
Reactions: Jags
It doesn't have to be slow. Gears do wonderful things.
I bought it. I had one just like this years ago and it worked great. Not slow at all, only probs I had with it was the reverse was finiky and I had to replace the rubber wheel that reverses the screw a couple times. Lampson tractor in Ukiah was able to find parts for it. They told me it was actually made by Ford Tractor.
On this one I looks like soemone has moved the mounting location of the motor (not sure why) so the pulleys no longer line up. The drive mechinisim all seems to be working fine when I turn it by hand. Motor does not have any spark and carb looks messed up. Just going to replace it with a harbor freight 6.5 hp motor and remount it so the pulleys line up. When its all done Ill repost how it turned out.
Reactions: n6crv
No spark most likely can be cured by filing the oints and resetting the gap. Common on these old motors that sit awhile. Clean that carb out and you may have it going for next to nothing. ;)
After messing with the motor it still would not start. I decided to go with a 6.5 hp motor form Harbor Freight $109 well spent as it starts easily and has plenty of power.Here is a short vid of it running.
Reactions: n6crv
Look at it this way, you have a wood splitter that works for you, and you only have 300 bucks and a little work into it. I think you did alright!
Is there a way to stop the reverse (or even forward) so you don't have to use the entire stroke? If so, that would speed up thing nicely and would be less wear and tear.
Reactions: n6crv
Then the process could be sped up a lot. Using the full range really would make this one slow.
I wanna see more video. That was cooool!
Where can I find a wheel that will work on the reverse on this log splitter? And what is the part number? I have recently purchased one on cl houston and cant seem to get reverse to work.
Here's a video off utube.
Maybe post a pic of what you are looking for and where it is located on the machine. Most people have never even seen the working components of one of these things.
I did find this, but it is in ref to the Gilson snowblowers. They do state that some parts are re-manufactured stuff. Maybe they could come up with something for you:
http://www.gilsonsnowblowers.com/snowparts.html
