I have a Napolane Insert, with a partial installed linear in the fireplace which I've been using since October. So yesterday I go on the roof, and took off the chimney cap and looked down and saw the flue tiles covered in a black glazed creosote (stage 1 from what I've read). I swept out the chimney but there was no build up. In fact the brushes did nothing to remove the glazing. Its not thick, as I can scratch it off with my fingernail to see the tile underneath. So after I saw this I thought I read somewhere on this site that this is a bad sign. So I went out and bought one of those expensive cleaning logs. Before I used it I ran the stove hot to 550-600 and then after the wood burnt out and the temp went down to 450 I placed the log on top.
So a few questions if I might
1. Is the glazed creosote normal. I know creosote is and will form but I have not used this stove everyday for the last month or so.
2. If this is not normal what is my solution to clean out the glazed creosote? Or if I fully line the chimney will this prevent it. BTW my flue tile size is 6-1/4 x 9-1/2
Frank
Frank
