Hi,
I’m new here in the wood stove forum, but not to Hearth.com. Back in ‘05 - ‘06 I spent some time here getting input on a pellet stove. That’s served us well but is starting to get costly to maintain. That and recent power outages have convinced me to go back to burning wood.
We currently have a 2006 Enviro Empress free standing pellet stove that will be sold as soon as I get the new control board and get her fired up again. I’ll post a picture as soon as I’m able to do so. It’s already had both fans replaced.
The Empress is rated for 35k btu, and heats our 2100 sq ft raised ranch well until temperatures dip down near zero and/or the wind really blows. All by itself the temperature upstairs is usually 4-8 degrees cooler depending on how cold it is outside. For several years, at my wife’s request, we had a second one on the upper floor at the opposite end of the house. Together we were very toasty all the time. The upstairs stove burned about a ton a year, and 2 1/2 to 3 tons downstairs.
Now the upstairs Empress resides at my youngest daughters house, where it drives them out of their super insulated cape. It’s been replaced by an 18k Mitsubishi air source heat pump. That’s been our upstairs backup and our air conditioner for 2 years now and it’s great so far. Very cheap to run for heat and A/C.
I’m looking at replacing the Empress with a Woodstock Soapstone Fireview. I’m hoping it will heat our entire house without driving us out, and I believe it will despite our previous experience.
Prior to the Empress we had a Jøtul 3CB on the hearth that we bought new. That stove got us through the ice storm of ‘98 when we had no power for 10 days. But it was extremely hard to regulate and we didn’t use it much because it would drive us out of the house without a window open. Consequently it didn’t get used a lot, and when oil went up in price I sold it and installed the Empress. I didn’t put 5 cords through it in 10 years. We only used it when it was really cold.
I wanted soapstone when I bought the Jøtul but just didn’t have the money at the time. I believe I’d still have it though if I had. I’m looking forward to any input I can get. Anyone have a similar situation, or seen one? A friend of mine in northern Maine has had a soapstone stove for about 40 years now, and the thing that always impresses me about it is how even the heat is. Unlike cast iron stoves I can actually stand or sit near that one comfortably.
The rest of the plan is to also add a second heat pump downstairs, as well as a heat pump water heater, and eliminate my oil boiler altogether. I can’t wait to get oil off my property! The heat pumps will be used in the warmer parts of the shoulder seasons, and when we’re gone too long to maintain a fire. Solar panels are in the long range plans to make us completely independent hopefully.
We live in southern Maine near Sebago Lake, for the past 24 years. Prior to that we lived in northern Maine, where we always burned wood as a major heat source, so I have lots of experience with wood, but not with soapstone. We’ve had 3 steel stoves and a beautiful red Resolute Acclaim back in the early 90’s that we loved. Our busy lifestyles got us away from wood, but the kids are in their 30’s now and we’re close to retirement age. I’ve actually been disabled from the past 9 years and my wife has been handling the pellets because I can’t handle 40 lbs. I can handle a couple splits though.
We have a field stone hearth at the north end of the house with an exterior brick chimney with a 4” SS liner in it currently that will be pulled. I’l have the chimney cleaned and inspected but I’ll do my own install with the help of my SIL. I used to turn wrenches in the wood harvesting industry so I’m well versed, just not as physically capable as I used to be.
I plan to drive to NH to get the stove at the factory and take a little tour. I have looked at other soapstone stoves but haven’t found a stove or a manufacturer that I like the look of nearly as much. Perhaps someone has some input on that? I’ve done a bunch of reading here and I can’t seem to find anything bad about Woodstock or their products. Am I missing something?
My hope is that with a small convection fan on the stove we won’t need to run the heat pump upstairs 95% of the time and we’ll still be able to sit in the family room where the stove is and enjoy it. What do you guys think? I’ll post a picture of my hearth as soon as I can. I uploaded one but it’s being reviewed.
Thanks for your time!
I already knew a bit about Woodstock since my SIL had bought a Fireview used, and that's where I first saw the heavy-duty parts and the design features built into their stoves, things like all cast iron parts in the top of the stove and the ease of cumbustor removal for dusting..lift the lid, pull it out..it took all of three seconds.
Her 10 yr. old stove had some air leaks but I'm convinced that it was over-fired more than once by the original owners..the combustor scoop was warped but thankfully none of the other components in the top of the stove were damaged, owing I think to the heavy-duty construction of these stoves. Woodstock parts prices are reasonable, so that helps as well.
