Going to be building new house, Fisher Mama bear questions
XxDarkEuphoriaxX
12
Southern Indiana
Some background info: 20 years old, planning on building a house with my dad for around $10,000 around 1200 square feet. In the next 2 years or so I am going to be building my first house...It is about 2 acres away from my parent house in the woods behind the lake and a small amount of field. This woods is not that big, between 3-6 acres I am not sure exactly how much. The house is going to be a rectangularish one story simple house. UNfortunately my grandpa had the woods logged (only for the good stuff) and they pretty much destroyed it. It is slowly growing back however, this was done 2 years ago. I figured the only logical thing to do was to put a wood stove in because of the extraordinary amount of wood laying around, and the fact that I believe the woods will sustain a small wood stove pretty easily. I plan on adding an additional 5-10 acres of woods that is now field in the next 10 years if at all possible. (It will eventually be my parents field)
I have been doing a lot of research on models and My number one option would be a woodstock fireview. However it is extremely expensive. Second option Harman Oakwood. My girlfriends grandparents live in Salem Indiana and they have a Fisher Grandpa Bear? I believe... anyhow it has 2 doors. The house is old and poorly insulated and it seems to only really heat one room really well anyhow.
I came across a Fisher Mama bear in good to excellent condition. The asking price is $500... a little steep? It was just re painted.. if it was repainted with stove paint it won't melt off will it? Do you guys think a Fisher mama bear used will be worth it and head a 1200 sq. foot house? I want something simple that heats and works. Something quality that won't break no matter what I do. Is there a large risk with using this stove? I think a lot of the newer stoves are cheaply made and will never buy one unless I think it is going to last like a harman oakwood or woodstock fireview which I can't really afford right now...
Thanks... :)
I would hold out for a newer EPA stove. the old fishers are nice and well built, but your going to burn through 2x as much wood for the same amount of heat as well as have to get up at night to keep the fire going. I got my napoleon for 550$ brand spanking new on clearance and it doesnt seam to cheaply built to me.
To stay on budget, I'd get a new 2 cu ft Englander, Napoleon, Lopi or Pacific Energy stove. You will get a tax credit for the entire installation. Run the flue pipe straight up in the interior of the house. This is assuming with new construction that the building will be well sealed, tight and well insulated, right? If so, a 2 cu ft stove should do the job for you.
Then again, maybe not. Unless the materials are free, it's going to take a lot more than $10K to build a 1200 sq ft home. Was there a zero missing from the end of that number?
Yeah the house will be well sealed, insulated. My dad bought a house that caught on fire and was completely burned out with a hole in the roof and he did all the insulation, tile, carpet, siding, wood flooring, plumbing for the house so he knows how to do it all. The only sketchy part is the actual frame and foundation which will be crawlspace.
So you guy's think I should forgo the Fisher? I kinda like antiques and the like and like the rustic type look of the stove...
No way on earth would I even consider that stove. For almost the same price you can get a pretty darn nice EPA stove and get more heat from less wood.
I agree with the fisher comments, When I had a moma bear, I used to heat the chimney of my house real well, never worried about creosote and went through a whole lot of wood, I switched to a VC Defiant which is still nowhere near efficent as modern stoves and cut my wood usage by about 1/2, the only thing I miss is that my chimney doesnt heat up anywhere as well now as it did with the Fisher.
If you like the rustic look, maybe take a peek at a Pacific Energy Alderlea T5?
I still like the Fisher (and the story behind it too!) I want something that is simple and will last a long long time and the Fisher seems like the stove. I don't see how it could really be broken.... maybe replacing firebrick or some weld coming apart somehow but there is a welding shop near me that could handle just about anything..
I am going to have lots of room to store firewood and will have lots available so burning a little more than normal isnt that big of a deal..
I will have to consider somethings...
Fisher was a good stove for the time . . . and it still has a good look about it.
That said . . . there are a lot of benefits to burning with a newer stove.
1. You will burn less wood . . . less wood burned = less time spent cutting, splitting, stacking and moving the wood from outdoors to the stove and more time spent fishing, hunting, ATVing, hiking, etc.
2. You will get a nice view of the fire with most stoves . . . nice view = romantic moments in front of the stove . . . or simply having a nice focus point in the room . . . no need for a fireplace.
3. You will burn less wood . . . less wood burned = your yard doesn't have to look like the yard to a pulp and paper mill.
4. You will burn cleaner . . . burning cleaner = cleaner chimney, less cleaning is typical (although you still need to check the chimney) and you get that good feeling knowing you're being "green."
5. You will burn less wood . . . but get more heat as most of the stoves in your budget would be secondary burners and what you will find is that it will "re-burn" the smoke resulting in more heat.
6. You will have a new stove with a known burning history . . . not a stove which may have been used and abused and just painted to cover up any signs of over-firing.
7. You will burn less wood . . . less wood burned = less money spent on buying wood or fuel for the saws, splitter, ATV or tractor, etc.
8. You will have a new stove for about the same, perhaps a slight bit more money than a 30-year-old stove . . . prices right now are pretty decent with the event of Spring . . . and couple that with the tax credit . . . it's almost a no-brainer.
As for dependability . . . hmmm . . . if I had a choice of buying a brand new stove with a warranty . . . or buying a 30-year old stove without a warranty and potentially 30 years of fires and who knows what type of usage . . . nah . . . again . . . a no-brainer for me. The steel stoves you would be looking at for the price point are nearly bullet-proof . . . just like the Fisher . . . only they've got one thing extra going for them . . . they're using welding techniques and product that is a lot newer to put these fireboxes together . . . not to mention the fact that they're probably being made at one facility vs. the Fishers which were allowed to be built at several shops. As for the construction, I would argue that the newer stoves have a few "extra" parts -- notably the "glass", baffle and secondary burn tubes . . . and yes there is a potential for these to be damaged (especially if folks are not careful) but I would say that overall very few people have problems with these items being damaged that often.
Hello Exdark, Hope you are able to harvest/process some of the tree tops remaining before you get your house built or even get a stove. Cut and down wood only lasts so long (4-5 yrs at the max?). Get some of it up off the ground and hopefully covered.
My bigger concern is that if you run that big Mama in a tightly insulated house that it may overwhelm the place. If the plan is to fill and smolder, it will be a creosote machine. (Remember that hole in the roof house?) And there is no opportunity to add an outside air feed directly to the stove if required. A modern stove is going to burn cleanly for you and will provide a nice fire view as long as it is fed dry wood.
I was thinking of installing some sort of pipe with a cap in the house so that air could be sucked thru it from outside to feed whatever kind of stove I decide to get... would a one inch pipe be big enough? Is this the only way to supply air with a newer house without cracking open a window?
So are you saying BeGreen that If I load this stove up and run it on low that it will make lots of creosote? This house will basically be a single story rectangle divided in two longer rectangles, a den and kitchen on one side of the house with no wall inbetween them (a bar separating the den and kitchen) and two bedrooms with a bathroom inbetween on the other side of the rectangle... I figure this is a fairly open floor plan. The stove will be against the wall on the den side so I am kind of concerned that the den will get too hot but i think the open floor plan will help. Really I wanted to put the stove inbetween the kitchen and den where it would be centrally located in the house but I don't think there would be enough room there for a stove with the bar extending from the opposite wall... and I would not really be able to enjoy a fire if I get a stove with a window if it was in that location because it would not be in the den..
The reason I dont want to buy a cheap stove is because the stoves I saw at rural kind and home dept, I was appaled at the quality... one dispaly model had a broken door hinge... And the doors wiggled a whole lot and did not fit togeather that well to the stove. I would be scared to have one of those in my house. I may forgo a wood stove for a while until I have enough money to buy the best to begin with, which will probably be a Fireview Woodstock. or classic
Sounds to me like you need to educate yourself on stoves. Your considering a Mama Fisher but you think the best is a Woodstock Fireview? Do you realize that the Fireview is a CAT stove. The difference between those two stoves are further apart than night and day. Read the reviews on this site, learn about the stoves and learn about wood. It won't take too long. I was in a similar situation as you about 10 years ago. I didn't know anything about burning like I do now. I wound up having to trash my first install and upgrade to something much better. That had a price tag of around $4000 before I was done. I have a ZC fireplace which is basically a stove in the wall with the brick around it to look just like a fireplace. Don't take to lightly what these guys on here suggest. They're the best at this stuff I've ever read. If you don't understand what they're telling you then try to learn so do understand where they're coming from. Your in a good position right now, no commitments yet. Learn and start cutting and properly seasoning wood now. That's where I would start. Figure out where your going to store it, can you keep it dry enough, what kind of wood will you be using, how much will you need to be a good two years ahead (especially with a Fireview), what kind of equipment do you have for harvesting and how much time do you have to do it and most of all - do you enjoy it Good Luck
What was the brand of stove at the big box? They sell everything from cheapy stoves to decent ones, but perhaps they didn't have an Englander on the floor at the time?
By all means try to centrally locate the stove. The PE Alderlea's are very close clearance. Where the Fisher would require 36" from combustibles, the PE is less than 6" (not at my desk right now).
Do a bit of research, there is a lot of difference between some stoves.
It was summers heat I think? piece of crap. I have been looking at the napoleon 1100C hopefully it is better, there is a local fireplace store but for some reason they never seem to have the stoves on the floor that i am interested in looking at.
If looking at Napoleons, also check out the 1400/1450 for the bigger firebox. Napoleons also have good close clearances. Pacific Energy's Super 27 also falls roughly in this price range and is a well built stove.
You best do some more research as you just put down a very good stove that will blow that old " pc of crap" Fisher away.
Your building a new home, and your going to put an old, inefficient pc of crap in it?
And having "plenty of wood" lying around is not excuse to justify using said older stove. Let alone wasting wood. Less used, is less processed, and less work.
Seems to me your rushing into this thought process, and already know what you want to do.
Keep researching and get yourself better informed & educated. Then you can make a sound decision and feel confident in that decision.
You do realize Summers Heat is Same as Englander right? Insert foot in mouth.
