Good brand/sources for new cast iron radiation units
Thom Griffin
36
Ideally, I'd like to eliminate a bit of my fin baseboard in favor of old cast iron radiators if I can find them (I have a bunch installed already and really like the heat) or even the new then wall mounted cast iron things that I've seen.
Also, what are the best sites for heat loss calculations? I'd like to balance my heat a bit better than it is now. In the 20 years since my initial install, I've removed various walls.
One last question: At the current time, I don't heat my upstairs, and none of the loss calculators I've seen have any category for this. I do intend to eventually put a loop up there for occasional use.
You have to treat your unheated space as a "plenum", since you lose heat from the first floor to there, and then from there to the outside.
Easiest way is to run a load on the ceiling of your first floor like its a roof with a minimal R value, and assume that the outdoor temps are 45 or so (or whatever it is that your upstairs is without heat). Then for the upstairs, calc it as your normally would. Those loss values should get you close.
Not sure if I can post it here but I have a spreadsheet that calculates btu output of baseboard at different temps, heat loss of house at different temps, btu's stored, boiler runtime, etc
