Why would you want to do that? Unless you are having a flue fire, there should be no reason for this. Aluminum foils works so I hear.Just like the title says can you use gorilla tape to plug the primary and secondary air inlets?
Have you tried a pipe damper?I heard others closing off part to try limiting air. all I have is gorilla tape is why I asked. One guy on his napoleon even re welded the metal slide to close down more. I thought I would try a less permanent approach with tape
This stove has a 15-16' pipe at high altitude. I strongly doubt it needs a pipe damper.Have you tried a pipe damper?
I didn't know that, or missed it somehow.This stove has a 15-16' pipe at high altitude. I strongly doubt it needs a pipe damper.
It always amazes me me that we think we can out think years of engineering with duct tape.
Your stove sounds like it's working fine. Spend the rest of the season observing instead of tinkering. Random secondaries are common when the stove is at the perfect point of burning. Grab a brew, sit back and enjoy the light show.
I know its finally working good. And the more I have learned about it the better it gets. But I am a tinker so I have to play with things sometimes to understand them better. Its fun, what else can I say.
So I tried the aluminum foil and I have a question. Now before and after it seems to run the same just at different spots on the air control. So why do my secondaries pulsate filling the entire stove and then nothing. On YouTube many people get a continuous cloud. On mine about the time the bottom flames on the wood get lazy the top keep pulsating. Do the secondaries need more air or does the stove need better wood, better operator?
Well as BB so well stated a few weeks ago these stove were designed to burn clean (pass the EPA standards), nothing less nothing more so is it any wonder quite a few on this forum are modifying there stoves with tweaks here and there.100's of thousands of dollars go into a stove design, why not just let it do its thing?
Unless there is some uncommon issue due to an uncommon setup, why mess with it?
The majority of stoves out in homes do not need tweaking. These are fine tuned machines. Tweaking without a real understanding of what one is doing can lead to poorer, dirtier burning. Reminds me of a relative that just couldn't leave well enough alone. He took a perfectly beautiful Fiat 124 sports car and "tweaked" it. This was a new car and his wife's favorite. After the tweaking his wife would not drive it again.Well as BB so well stated a few weeks ago these stove were designed to burn clean (pass the EPA standards), nothing less nothing more so is it any wonder quite a few on this forum are modifying there stoves with tweaks here and there.
I agree with you. They don't want you to burn low and slow (smolder) on these EPA approved secondary tube stoves.The majority of stoves out in homes do not need tweaking. These are fine tuned machines. Tweaking without a real understanding of what one is doing can lead to poorer, dirtier burning. Reminds me of a relative that just couldn't leave well enough alone. He took a perfectly beautiful Fiat 124 sports car and "tweaked" it. This was a new car and his wife's favorite. After the tweaking his wife would not drive it again.
I just reread the thread and understand now.The OP's case is not a high-draft issue at all. Actually I think in shoulder season it will have low draft symptoms due to the 6000 ft altitude. In high draft situations a pipe damper is preferable for most as it doesn't permanently change stove performance or risk voiding warranty.
