Hello everyone - newbie alert. I have a Grandpa Bear III with an 8" rear vent that I plan to install in my barn. I have attached a pic of the install area and have a few questions regarding placement and stove pipe.
1) How far should I set the stove/stove pipe from the inside wall (will use brick or cement board on wall behind stove and pipe)?
2) What type stove pipe should I use in the different areas?
3) Should I reduce the pipe to 6" from the stove?
4) I will have to offset the pipe for the upstairs roof overhang. Is this OK and should it be inside or outside (as shown)?
5) Do I need to go 2" above the top ridge (about 8' away)?
Thanks in advance for your guidance....more questions surely to come.
....I purchased the Woodburner's Encyclopedia that you recommend and it too has a lot of information. Once I get the stove cleaned and painted, I may post a pic to make sure it is what I think. I'm using your recommendations from earlier posts on the restoration and also on a baffle.
