We are having a brand new Castleton Soapstone wood stone installed next month and are doing the hearth pad ourselves. Looking for information on using a solid slab of black granite as the hearth pad. A Google search has turned up little info on using granite under a wood stove and the few references I found recommended a slab 2 or 3 inches thick which seems a bit excessive. The stove has built in heat shields etc so my question does NOT revolve around heat protection but around supporting the weight of a 475 pound stove. The slab will be laid directly on the subfloor and be fully supported.
