- Dec 21, 2005
- 119
Can anyone tell me about this deal? Looks good,but am I just throwing away my money? I am trying to find a mid-priced sharpner has anyone ever used this one?http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93213
wingnut said:Thanks Roo Off subject but how do you get the link to work?
Thanks Paul
For some not so computer savvy as spike Highlight the address and press control then c go back to the forum in your message and hit control then v............My kids taught me that one :red:wingnut said:Thanks Roo Off subject but how do you get the link to work?
Thanks Paul
!wingnut said:That didnt seem to work eather Roo your links are in blue,that lets you know it is a link. I coped and paste but it did not come out highlighterd blue?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93213wingnut said:Thanks for ever-ones input on the sharpener. Roo that is what I did the first time I sent the link? Do you have to hit any of the bars above the reply like code or @ <a> ? I know it should not be this hard. When I copy and paste it does show up but when roll the mouse over the adress it does nothing?
Thanks Paul
earthharvester said:I say go with hand filing. Thoes grinders eat chains up. We have one at work and no one uses it.
That chain would have to be pretty bad for me to need something other than a hand file.... I mean were talking about what maybe 4-5 strokes normally per tooth?DiscoInferno said:earthharvester said:I say go with hand filing. Thoes grinders eat chains up. We have one at work and no one uses it.
I've seen this statement a lot, and it confuses me. Even the cheap plastic HF unit under discussion has a knob for setting how much to cut. You can take off as little as you want. Now, for a chain that is really screwed up, you may need to take off a lot; here hand filing would be a huge pain.
I'll agree that hand-filing is an important skill to learn, but I clearly have yet to master it and eventually my chains become unbalanced. A grinder is a way to "reset" things now and then, to get more life out of a chain. For $20 I'm happy, although that $99 unit looks so much better made.
Chainsaws are for wood not rock :cheese:DiscoInferno said:I typically do 5-10 per tooth, depending on how dull. But if you hit a rock, or have really sandy wood (both typical at times for me, unfortunately), then you can scrape off the hardened outer coating back quite a ways. Then 5 strokes won't produce an edge that lasts. The new chain I hit sandstone with, I couldn't rescue with something like 40 strokes. (Which isn't to say that someone better at hand filing couldn't have done so.) But with the grinder I took off maybe 1/16" or more quickly and uniformly. Certainly the chain lost a lot of lifespan, but at least it cuts again.
GVA said:Chainsaws are for wood not rock :cheese:
No i'm just kidding with you here, I understand where you are coming from but for me it's like the "should I buy an ash vac" question..... For the # of times I would use it it just is not worth it......... To me
