OK so I am chasing down a problem with my Harmen Accentra Insert and need help in diagnosing a new problem. Last Spring I had the pressure switch go out so I replaced it and the stove ran fine up until this past December. At that time, the stove would only run on Low Stove temp mode. When I ran it above 9 Oclock on Stove temp or on 70 degree room temp mode, the auger would stop feeding even though the feed light would be on. I had issues with some of the pots on the board as well and further diagnosed that the board was bad so I replaced it 2 weeks ago.
Once the new board was installed, I got full functioning back BUT... I started smelling exhaust in the house. I noticed that one side of the insert wasn't latched properly so the flue gasket was not sealing properly. Tried cleaning that up but still couldnt get a good seal so I ordered up a new gasket. (this is an 06 model and has been our primary source of heat for 10 years). Now that the gasket gives me a nice tight seal, I plug the stove in and get a 2 blink error.
As far as I can tell, this is an early model and does not have the hopper switch. The seal around the hopper seems to be good as well. What else is there for me to check?
One thing I did notice in the past few months when it was operating the stove a full range of heat settings is that the flame seemed a bit lazy. I thought it was a new brand of pellets I got, but even the old pelets had a lazy flame.
What controls the flow of air behind the burn pot? I think this could be the cause. I have jumped the pressure switch to get the stove to bypass the 2 blink error but now, the burn pots fills and the starteer gets hot, but no air seems to be feeding the stove to get it started. I can hear the blower working but not sure if some other fan needs to be working to get it started.
your thoughts on this are appreciated.
Thanks
Joe
Thanks
Joe
