Hello, I just replaced my Quadra Fire 1100i with a Harman 35i. Quadra Fire had a lot of info available explaining how the stove worked. It was very simple, when the thermostat called for heat it kicked on and gave me heat. When it came to temp it shut off.
The Harman, not as simple. I have had it now for a couple of days. It is set on room temp mode with auto ignite, a feed rate of 4 and the distribution blower on highest setting. It is heating the house just fine and keeping the temp between 69-71 degrees. I am use to the Quadra Fire starting and shutting down as needed for heat. The Harman has not shut off since I started it. The fire will die down and get bigger, I assume to keep the house at the set temp.
My question, Is it meant to run constantly with out shutting down? Is it OK to run it like this and only shut down to clean? I use the stove as the main source of heat for the house.
Thank You
Alan
Thank You
Alan
