Harman Accentra Feed Motor Intermittent
joetiii
16
So this tale is getting more bizarre so I figured I would post a question on the forum to see what my stoves problem might be. At the end of last year the feed motor on my Harman Accentra insert stopped working completely. In diagnosing the problem, I first made sure the stove was clean throughout and then jumped the vacuum switch to determine that I had a faulty switch. I replaced that part and the stove has burned about 1/3 ton this season with no problems. About two weeks ago, the stove burned out so I restarted it. It ran for about a day straight and then the flame went out again due to the feed motor not working. I restarted the stove and it would run for about 15 minutes and then again the feed motor stopped working. I pulled out the stove and made sure that everything was clean including the flue figuring something was interupting the air pressure. There was some watery sludge on the left side exhaust port which I have encountered before from rain/sleet/ice coming down the flue and settling in the square exhaust tube on the left. I cleaned all this out and got the sove o run on its own without going out. However, the stove now has a mind of its own and will not respond to either the manual or temperature control settings. It varies between being full on heat or on low heat setting. I am thinking I either have a bad control board or I have some moisture in the pathway for the vacuum switch. Has anybody had this happen before? What should I check next?
My Harman is an 06 model and has been faithful for 10 years. Aside from regular cleaning, I have only had to replace the ESP 2 times and then an ignitor once besides the vacuum pressure switch. My stove runs constantly from November through April.
Sorry no one got back to you sooner. On surge protection? Checked thermostat, room probe wiring?
Hopefully one of the other Harman owners will have a better clue if it is a board problem... Potentiometers do fail over time too.
Have you tried running it in test mode? It might be the dreaded spotty pot (potentiometer) problem. Try working the knobs back and forth real fast which sometimes wipes the dead spot clean.
No I am not on a surge protector.
For 5-6 years I used the room temp side of the pot and the pot developed a dead spot in it causing on/off problems. I have used stove temp since and make sure to vary the heat setting daily. This problem happens regardless of whether it is on the stove temp side or room temp side.
I am not sure why the room temp side would cause issues when stove is on stove temp. Please explain.
I have run in test mode just after the stove shuts down and the auger does not turn. Funny thing is if I let the stove cool down, it will start right up with the ignitor (no gel) and then work as it should until it decides to quit. Could be 10 minutes , could be 3 hours.
If it had a high limit switch, I would say that was it ... Might be time for a board repair and a surge protector.
Well first off,you do not have a stove,you have an insert(woop yep big difference!!).You already figured out your board was going bad,yet you did not replace.Not gonna waste anymore of my time.
I posted earlier in this thread and, guess what, my feed/auger motor quit too. I made up a test cable and plugged the motor straight into an outlet and nada, nothing, barely even a hum. Fortunately my dealer had one in stock and $10 cheaper than the online price.
It's easy to replace. I have the chain drive version. I removed the tension roller, pulled the motor sprocket and chain, loosened the mounting screws, and it slides out. The installation is the reverse. The toughest part of the job was carefully cutting the wires ties without cutting into anything else. It takes less than an hour. Easy peezy even for a first timer. BTW, my stove is 10 years old so I guess it was due.
Reactions: Lake Girl
