Hi all,
The short version: the inside of my stove is filled with smoke. It failed to light, and apparently failed to exhaust any smoke. I have five blinks on the control board, indicating that it tried to light, but timed out. Combustion blower? The light on the control panel indicates that it is sending power to the combustion blower, and I swear I hear the blower. But smoke is not evacuating from the stove (unless you consider the tendrils of smoke coming out where there should be heated air!). Stove was manufactured April 2006. Thoughts?
Longer version: I can't tell you how much I appreciate this community, and all that I've learned over the years. I bought this house four years ago. It came with the stove, which was clearly neglected by the previous owner. I read on this forum how to perform basic maintenance on the stove. Every time the stove fails (which is frequent), I go to the forum, and find some other part that I didn't know about that I have to clean. So far this winter, the stove was performing pretty well. I would run it for about 5 days (five bags of pellets). Shut it down, pull it out, and clean everything. This includes (from the front) the burn pot, under the burn pot where the igniter is, the two cavities on the left and right toward the bottom of the heat exchangers (right side is for exhaust, not sure what left side is, but that is typically dirtier), the heat exchanger and the whole interior, really. Around back, I open the little box under where the pellets are fed from the hopper to the auger (sorry I don't have all the terminology yet), the housing around the combustion blower, and then use my chimney brush with long extensions to get the whole flue. I feel like I do a thorough job, as it takes me about an hour, but I have thought that before only to discover I was missing something else.
I'll be honest...I hate this stove. For the amount of work that goes into it, and the heat I get out...it doesn't seem to be worth it. And it is just so unreliable. It fails at least four times a season, causing me to spend time researching what's wrong, and troubleshoot, or order parts. I also only go through 50 bags per year. For how much I use it, it seems more trouble than it is worth. I suspect much of this could be due to my inexperience / ignorance of pellet stoves. But I would consider myself of reasonable intelligence and mechanical aptitude. I read through the forum and hear stories of folks heating an entire house with their stove! I'm so jealous! I can heat one room with it...when it is running, and everything has to be just so. I'm tempted to rip it out and put in a wood stove. Less moving parts!
If you've made it this far, thanks for reading my rant. Clearly I'm desperate. I would love to know what you all think. Thanks for taking the time. Regards,
Michael
Michael
. Typically we do that once per year! Also at the age of your stove I would bite the bullet and get a new motor and fan blade. If the fan blade has not been off before there is a slim chance you will be able to loosen the set screw. And even if you can they can be siezed on the shaft. Then you end up damaging the shaft in the process and need a new motor anyway. I would start with a new motor and fan blade and service the bearings yearly instead of trying to resurect one that is already damaged. Doing it that way you just use a hacksaw and cut the shaft off to remove the motor from the plate. Also, when I have a fuse blow call on a Harman it is 95% the comb motor. Something electrically inside it shorts. So if you have had a fuse blow and bearings are bad and blade is stuck save some aggravation and replace it. They are not that much. And dont buy the chinese knock off motors.
