Harman Accentra Problems
fkarbo
14
Pittsburgh, PA
Had a repair guy come out to troubleshoot my Accentra. He went to change out the ESP, and the new one did not fit. The circumference of the probe is different (smaller than the new one). The one that was in my stove was white with a point, and he said all of the ESPs are red or black. Cannot find any on the Internet. Has anyone had this problem?
Was the wire red or black...what year is the Accentra..I think somewhere circa 07-09 they changed over to red(Digital) vs black(Analog) input. Most of the newer boards can do both via a jumper though.
The wire was white. The repair guy said they only had red and black, so I don't know what's up with it. I don't know the year because I bought a floor model and this is only my third winter with it. Serial # is 2624.
[Hearth.com] Harman Accentra Problems
Just found this from a stove dealer:
Mounts in the exhaust housing near the vent pipe connection. Clean with a scotch-brite pad or fine steel wool at least once per season. Wire Color There are 2 different thermistor ESP probes for the Harman line; one has a black wire, one has a red wire. You must order the same color thermistor probe as the one you are replacing. Please Note that the Black Wire ESP will also replace the early White Wire ESP Probe.
Reactions: Washed-Up
Wow. Thanks. Gonna try aa black one. I'm not sure the repair guy had one on him.
To find your stove build date look for sticker on the side. I also got floor model in 2018. Built in 2014. When new model arrived I got it at 1k discount. It had very little use in the store.
There isn't a sticker on the side...or the back. Just the serial number.
The Data Plate is Riveted In. Looks like this I bet. Look at the Bottom of the Plate for Date
  • [Hearth.com] Harman Accentra Problems
Here is mine. This thing must be older than I thought.
Well, this is interesting. Looks like the place where I bought it somehow cut off the manufacturing date. Look closely at my pics.
Pull that plate you may find that the date is under it
I'll bet if you peel back that lip a little you will find the rest of the sticker is under it
not cut off just covered by the lip
Reactions: ABusWrench
In the picture of the esp, the tag says 12-24-02. I agree, the rest of the tag is under the panel lip.
So I replaced the ESP myself after not hearing back from the dealer (that I paid $80) that came to look at it in the first place. It ignited and ran, but still low flame after about a half hour. Temp was on about 75 degrees. If I turned it all the way up, flame got larger. No blinking lights on the panel.
What mode are you running it in? Stove temp or Room temp? I assume room temp?
