Harman in line thermostat install burning out control board?
cjweaver13
11
PA
I am trying to set up a digital thermostat with my Harman accentra fs. I needed a new room sensor and told them what is doing. One of the guys said because I'm adding more resistance to the circuit that I could eventually burn out the control board, and also the fact that the digital thermostat and constantly opening and closing the circuit.
Any truth to this? First I've head of it in the research I did but he's been working on stoves for 25 years so not sure if it's just a line to cover their own arse or some truth to it.
cjweaver13
11
PA
Any problem with the stove being in the 4 blink error mode half the time while waiting for digital thermostat then?
railfanron
584
Perry MI
Been running mine for 6 years on an external thermostat. Last 2 on an Ecobee Plus. No problems.
Ron
bogieb
3,415
South Central NH
I run both my stoves on exterior thermostats so they are always in 4-blink mode when they aren't firing. Rright now the P61a is running about 1x per day, if that, so that's ~23 hours a day it is blinking. The P43 goes between not running at all to running 5-6 times per day (during the late summer / fall weather). I haven't had any problems at all.
bogieb
3,415
South Central NH
Urbanhopper
2
CT
I've had mine running with a millivolt programmable stat for nearly a decade and no issues. I recently connected a Nest using a 24vac relay and it's just fine. Now I can actually get data on how often it duty cycles and control it from anywhere. I want to connect a smart switch access to the igniter next and have full control to turn it on and off completely.
