New to the forum, I finally joined after searching the web & constantly being directed to the site. I have a Harman Invincible insert that I bought used in 2013. I installed it in the early fall and it worked flawlessly all last winter with routine maintenance. I gave it a real thorough cleaning at the beginning of this season & it was working fine up until about 2 weeks ago. It would not stay lit & had a lazy flame that seemed to be rolling toward the door of the insert instead of towards the flame guide.  So far I have pulled the insert, cleaned every nook & cranny (including the 4" flexible flue pipe to the roof and the EGT sensor), replaced the door gasket and flame guide. The only way I can get it to stay running is to turn the temp all the way up in stove mode and crank the feed rate up all the way to 6. After searching the forum for info, I am suspect of the burn pot gasket and the auger motor. I was able to get about a quarter turn on all 4 nuts holding the burn pot in, but I am not sure how to diagnose a bad gasket without actually pulling the burn pot itself. As far as the auger goes, it is feeding pellets, but I am not sure it's feeding enough. I don't want to keep throwing parts at the thing, but I really don't want to kick my electric baseboard on either!$!$ Any help or advice would be greatly appreciated.
