so i have a chance to get a Harman magnafire insert for a good deal. I want to replace my jotul to burn coal. I believe the harmans flu is a 7" oval and my liner is 6" round. Csn i get an adapter to hook this up?
Did you buy the jotul new?Yea blowers fine took apart many times checking it rope comes off from bumping it. I have it fully roxuled in with a sealed stainless and insulated block off plate. Ive tried every kind of wood. Even kiln dried oak thinking my wood was to blame. I am def ripping it out and putting on craigslist.
Then it is not installed correctly.rope comes off from bumping it
Did you ever test the moisture content of the wood? Most "kiln dried wood" is really only heat treated to kill any bugs so it can be transported across state lines.Ive tried every kind of wood. Even kiln dried oak thinking my wood was to blame.
Did you contact jotul to find another dealer or someone else to service it? I have worked on many of both of these stoves and honestly have yet to really hear a complaint about the jotul. And the liners on the harmans if they are used for wood are usually a total mess I really doubt that liner you have will hold up long at all hooked to that harman between the coal dust and the more vigorous cleaning that will be required from burning an inefficient wood burnerYea was a floor model the dealer had since they went to single doors. Dealer i bought from was pathetic to say the least.
Ok but how did you put it back on after it came off?Rope was installed at factory
Clean it toughly and then use high temp silicone it wont come off again.Used rope cement from lehmans. Which sucks due to having to let it cool down and wait days to reuse it
