Has anyone tried a Fasco A172 (motor only) for use as a combustion motor replacement on the P series stoves? I have a friend that can get them for much less than the Harman replacement (OEM) combustion motors. I was thinking about having him pick one up, then comparing the overall size (again, motor only) to the original; rotation, shaft length, diameter etc. just to see if it will work I was just thinking it would be a decent replacement if it is the same; it would be a Fasco (also others use OEM part numbers of the same) and may last longer than the cheap Chinese replacements. I see the comments about the second fan not being needed on the combustion fan (found on the original), but I believe Harman started using the double fan to help with the heated environment in the original design. Thoughts?
