Harman P43 making odd noises....
joeljjk11
10
MA
For about a week now my Harman P43 has been making odd noises. It makes a constant whistling noise and also makes a loud helicopter type noise that lasts for about 10-15 seconds then goes away. My pellet stove guy looked at it and was not sure what it was so did not replace anything. He thought there could be a pellet jammed in one of the fans that is causing it. I feel like it has something to do with the combustion blower but I really do not know. Anyone have any idea what it could be? Thanks!
Could you post a video?
This is the best I could get because for some reason the stove wasn't making the real loud noises. But it is like a da-da-da-da noise like a helicopter that lasts for 10-15 seconds. You can hear the loud pitched whistling which is constant.
I would bet your exhaust motor has developed some end play, and when stove calls for high speed, it moves out or in and is touching/scraping on the stove or the cover.
Reactions: Washed-Up
Any idea on how to fix this or does the exhaust motor need to be replaced?
What year is your stove, I’ll look up which exhaust/combustion motor you have. The older ones have 2 blades and a cast cage on the outer fan
On the back of the hopper you’ll see a plate that has the test date on it, I’ve circled it in red in the photo
[Hearth.com] Harman P43 making odd noises....
Ok yours should look like the photo below. With the stove off, you should be able to spin the blade to see if it’s contacting the cage and also see if there is any end play in the shaft.
