Harman TL 300 Users
Sure, if it starts to rot or get punky. Wet wood will get lighter as it dries, and dry wood will get lighter as it... well, whatever it does to turn into that flaky, mushy, powdery junk (look up dry rot). But that should not happen if the wood is kept dry.
MishMouse said:
trump said:
How were the thighs? My grill has a very thin tabs that hold it in place and my door seems to close all the way with the grill in place, the manual does not say wether you should have the door open or closed during cooking, but i was assuming by the way they made the grill to fit in under the door it would be closed. Has sanyone used the fireplace screen yet. Im told that you must leave the vent door open (no afterburner) during this operation to avoid smoke spillage and pull combustion air in through the screen.
IM not getting much burn time cuz Its too damn warm out yet.
The thighs were great, they probably would have been better if I didn't try to do low fat cooking by removing the skin and the temp wasn't above 500 when I put them on. As for it closing I noticed that it does close but it is not get a complete air tight seal so air does get pulled in from the room especially if you close the primary air down. Today I fried up some chrizo sausage and portabella mushrooms.
If you want some cold weather you can borrow some from me, today we had a high of around 28 with light snow and a 20-30 mph wind. Funny thing come late Feb I will look at the 20's as short sleeve and light jacket weather. :gulp:
Last year we had lows below -40, I could tell the coldest day the thermometer stopped working when it hit -40.
I haven't bought the screen yet, but yes you would have to run it with the damper open.
I totally know what you mean, I once made the mistake of buying a thermometer from walmart, darn thing won't show anything below -20. Thats the point when you really need to know the temp. A few winters ago my wife went out to start her car and said wow its really warm out today what the temp, I looked and it was -20, that how you know you live in the north.
Mike
trump said:
Does anyone know if those Eko boilers they advertise on this site actually turn the wood to gas and then burn the gas ,or do they just burn the wood and also the smoke like a TL-300 or a Cat Wood Stove does.
They use the same concept as your stove. They burn the wood and the combustion gases. From what I gather from their website, I believe they have some degree of forced combustion air.
FIREFIGHTER29 said:
uptrapper said:
Wondering if you guys are seeing this? My glass stays pretty clean, sometimes when I start it up I get a temp haze on the glass but when the fire heats up it always burns right off. the thing I do notice is that the glass right behind the metal bars that keep the logs away from the glass need to be cleaned about every week if I'm burning at least every day. The glass isn't dirty enough so you can't see through it but just dirty enough so you notice it. I also notice the haze on the glass is in the same shape as the bars. I assume its because metal sheilds the glass from heat in these locations although the metal bars at times will look like they just start to glow if all the lights are out in the room and the damper is closed, might just look like it because of the hot coals. Anyway does anyone else notice this?
Thanks
Mike
I get exactly the same thing. But I have not noticed the andirons glowing red.
FF29 WHere did you get your internal flue pipe gauge? whats the brand name? and what did it cost? I can,t find a good gauge anywhere,not even at the farm supply store where thay sell wood stoves.
I ordered it through the same shop I bought my stove at. Its called Chip's Stove shop in Apollo Pa. (724) 567-7876. The thermometer is made by Condar and I think it was around $25.
  • [Hearth.com] Harman TL 300 Users
Does anyone here have any experience with CAT stoves and what can you say comparing them to the TL-300. The obvious diff is they light off at 500 Degrees,
I have never owned a cat stove, but the idea of possibly having to replace the cat after a couple to a few years use was enough to make me stay away from them. It would not be bad but the prices for a cat can be expensive.
The cats may be expensive, but your Harman combustion package will run $300, so take good care of it. It seems a cat stove needs a new combustor somewhere between every year and every ten years depending on who you talk to and how they run their stove, but a lot of people seem to get 3-5 years out of them. I don't know if anyone has a good handle on the lifespan of a Harman combustion package - I would hope 10 years (as long as you don't overfire or physically damage it).
Does anyone know of a way to heat water with these wood stoves.
I have thought about trying to heat water with my stove too, but never came up with anything that would be safe enough to even think about using. I would be also be intrested in a safe idea someone had.
Mike
I would start here: (broken link removed to http://www.woodheat.org/dhw/dhw.htm)
There is some very interesting articles at this site.
We finally got our stove installed last week! We are 3 days into burning and still are not sure if we got the afterburn going. We get the stove flue temp to about 600, have a thick coal bed and then switch to AB. Our temp then drops to 300 or below and it seems like the fire has gone out!? Have not heard any loud sounds. When AB is working is all the flame gone?
First a few questions:
1) When you say 600 is that external double wall temp or internal?
The internal flue temp should be around 1K when you start the AB or around 500 stove top.
2) When you say 300, what temp are our measuring?
3) How seasoned is your wood?
Ways to determine if AB is working properly.
1) No smoke from chimney
2) Stove top temps should stay above 400 when on level 1 and should hover around 450
3) An occasional flame or a rolling flame on the top of the wood
4) The amount of heat expelled when you put it in AB.
Before if you hold your bare hand over the top back of the stove you should feel heat but not enough to be unpleasant.
If you have it in AB you hold your hand over the top back and it will get uncomfortable quite quickly.
5) You may also hear a rushing sound when you first put it into AB sorta like a jet.
If none of these are happen or if you had a stall.
Just fire the stove back up to 1K internal flue or around 500 stove top and try again.
Since this stove is a downdraft stove it take a little while to get used to, but once you figure it out you will be able to get 10+ hour burns (stove top above 400) on level 1.
PS: On Saturday it was -10 outside, I was downstairs grilling a T bone steak on the grill over the woodfire and the temps in the basement were above 80.
Thanks for the input- I think it is going into afterburn, but it is hovering around 300 (internal therm. on the double wall chimney). I see a red glow in back of stove. I will try to get the temp up to 1000 before switching into ab, that may be our problem. We are getting the grill next week, can't wait to try it out.
Make sure your AB is fireing or you may convert your whole load of wood to creosote. i did this once and although the stove burned for 25 hours on one load of wood, i had a lot of creosote inside the stove , in the flue pipe , in the chimney. wood stoves like to burn hot, you need 1100 degrees at the AB chamber to light off the smoke, usually translates into 400+ stovetop temp. draft is importamt too in maintaining AF fire. You need good draft. A hot fire usually produces good draft. The colder it is outside the better your draft will be.
I made a wood stove out of an old oil tank , to heat up a large area and it throws a tremendous amount of heat with just a few pieces of wood in it, i guess its all that Sq feet of sheet metal is a good heat exchanger, the stove pipe will glow red if i let it get tto much air.
WHen you say 10 hour burn on level 1, do you mean the air adjustment all the way to the left as in minimum air. i got 27 hour burns already on the air at that position.
I have been part of these discussions concerning the TL 300 since I own one. Questions have always been when do I know it is in after-burn? All mentioned is true. What I simply do is wait 15-30 minutes when i have a the bypass shut and air down i simply look at the chimney for smoke or no smoke. No smoke all is well!!
Thats interesting that you bring that up Murry. Now that I have had some good cold weather and some time to really play with this stove, I have found that it will actually go in and out of afterburn throughout the burn cycle. I have found that sometimes I will load it up as normal get the after burn going and in about a half hour time it will stall. Then if I let it go, in time it will kick itself back in and continue to burn as normal. It may do this several times a cycle. The times I gave are not solid, it may burn in afterburn for an hour or two before going out. But my stove will go in and out of afterburn on its own.
Do you check your chimney to see if smoke is coming out?
Being a first year wood burner I may be looking into all of this to much, but safety is first.
I do check my chimney and when smoke is coming out it tells me it's not burning clean or the stove is not in the after burn.
I was just at one of the local stove shops and observed their burning tecniques. It amazed me of how simple thier stove operated. It was a down draft stove.
My observations: No smoke coming from the chimney. Flames in the firebox. Reload the man just threw the log in and shut the by pass, again no smoke from the chimney. They were busy so I could not ask questions. Stove temp was around 475.
This only made me think more!!
Murry, when I first started burning this stove I did look to see if smoke was coming out. Now, honestly, I can tell by the sound of the stove whither it is in afterburn. But on top of that, I still get up on the roof every month and a half or so and pop the cap off for a look. So far this stove is far better than my old englander 12. This time last year I would have cleaned the chimney twice. I have not cleaned it yet this year.
Iv had time to get back to my TL-300 and the first thing i did was build a little tunnel out of firewood so i have a clear view of the AF chamber. Now that i can see whats going on it is much simpler to get a good afterburn. WHen there is a lot of new wood in the stove(hence a lot of smoke) each of the AF air holes looks like a little blow torch with a flame shooting out about 2-3 inches. later when the wood burns down
some, the whole AF glows cherry red even on the lowest air setting.And the lower air setting seems to increase AF activity However i still have smoke (or perhaps its steam) coming from my chimney even when i am positive my AF is lit. If i try to engage the AF too soon it will start only for a minute or 2 and then go out. also i get no sound (that i can hear) when in AF. But then again the fan might be drowning out the sound. Either way this is the way to burn wood ,any other way except a cat stove is a waste of wood and all the BTU,s that it can produce.
I have some new things to report myself.
Last week we had a register installed with a fire vent.
It increased the heat in the upstairs by around 2 degrees.
So basement is running at around 82 and upstairs is at 74.
Just got the propain bill for 6 weeks of use, used only 30 gallons.
During this timeframe we had about 7-10 days that got above 0 for highs the rest were below 0 for highs.
Bill came to around 85 dollars with fees.
Last year at this time before Harman for the same period we used around 150 gallons.
At this rate stove will pay for itself in around 2 years.
To pay for stove plus installation will take around 4-5 years.
Add to that the benefit of the workout that you get cutting, splitting, and moving the wood to various locations, I come out ahead all the way around.
I would say that 90% of the time I get little to no sound at all from the afterburn. The only time I get the "jet engine" sound is when my coal bed is at least half the way up the afterburn throat in the back of the fire box. Sometimes it scares the $hit out of me when I kick it in lol. The one thing that is a for sure with my stove is I get a ticking sound (like what any stove makes when its heating or cooling) coming from my stove. But I can tell from the fast frequency and pitch of the ticking sound that the afterburn is working. And sure enough if I would look, no smoke. So after a point in time I would not waste my time and freeze myself to look. And to this point I must be doing something correct due to the lack of creosote and the awesome wood lasting potential I can reach.
It seems my AB goes out after a few hours on the lowest setting ,and the stovetop temp drops to 300 even with a full load of wood or at least the visible flame goes out ,so im trying it with the fan shut off for overnight burn to keep the AF chamber hotter, ill try various air settings until i can keep AF on all night.
