Harman xxv new flooring
Rick1524
4
Ohio
I just removed the carpet and put in hardwood flooring. The stove sits 1/4 inch higher than exhaust now. Does anyone have any ideas on what I can do? Currently I have a wall pass thru with outside air. Does anyone make a 3” flex appliance adapter?
Thanks
Rick
What brand of pellet vent are you using?
There is not enough give to get it recoupled? Maybe remove screws that secure pass thru to inside wall and see if you can get a little give?
Pull your pipe out of the thimble, take the thimble apart, cut the hole 1/4 higher with a sawzaw. Your thimble should have enough trim to cover 1/4” unless the original hole was way too big. Flex pipe is only to be used in wood burning chimney systems.
Reactions: Ssyko and DAKSY
In addition to what Overfireinthehole said, if you don't have enough material to refasten the the thimble cover plate,
you can fabricate an over-sized plate ...
Guys thanks for the replays. I think the first step is for me to take the wall pass thru apart to see if I can get any movement.
That is what I would do. You can also take screws out of outside part. You can probably get enough to get it hooked back up.
