DIY Woodstove Insert Install
Sb1911
21
Montana, USA
Hello. Looking for some guidance, I will be installing a used Quadra-Fire 5100i ACT insert in my basement fireplace. The old insert that was in there was an unlined slammer job from the 80s, I only used it once or twice, it ate a ton of wood and never seemed to put out much heat. The chimney has two terra cotta liners in it one for the basement insert and one for the main floor fireplace. I have a kit from Rockford Chimney Supply that includes a pre-insulated flex liner, appliance connection, top plate for my 13x 13 terra cotta liner, and a Vaccu Stack cap, as well as a wind/rain guard cap. I also purchased from Rockford some Furnace Cement and high-temp silicone. I have read the owner's manual for the 5100I ACT, and I have a few questions I need help with.
1.) Appliance connection- Per the manual, I can use two 1/4-20-3/4 hex-head bolts and the two existing tabs to secure the liner. This is a used unit, and the bolts are gone. Can I use stainless steel 3/4'' inch long self-tapping screws? When connecting the self-tapping screws, go through the pre-drilled holes on the tabs and appliance connector, then they will penetrate right through the liner? This would secure the tabs, appliance connector, and liner with two screws, if I'm understanding correctly. Does furnace cement go inside the stove collar prior to inserting the appliance connector? Does cement go inside the appliance connector prior to inserting the liner?
2. Liner termination point- As pictured, the main floor terra cotta liner extends just a couple inches higher than the basement. Should I run my liner 8" above the pictured top plate and then attach the Vaccu stack?
I appreciate any insight that can be provided.
[Hearth.com] DIY Woodstove Insert Install [Hearth.com] DIY Woodstove Insert Install [Hearth.com] DIY Woodstove Insert Install
I'd use an appliance adapter instead of screwing into a liner.
Also, inspect the secondary manifold carefully for cracks on the sides and rear of the firebox.
