Flue temp measurements, how hot is too hot?
FNG47130
4
Southern Indiana
First, thanks to this community for being such an informative resource.
Had a PE Neo1.6 insert professionally installed recently and am using a thermocouple screwed to the single walled pipe to measure flue temp. The mfg recommends it be installed 18 inches above the appliance, however the flexible liner is pretty thin walled and we weren’t confident in attaching the thermocouple into it via the self tapping screw. Instead it is installed onto the collar connecting the pipe to the appliance. Probably about 4 inches above the top of the insert.
Any guesses as to the actual flue gas temp inside the pipe in relation to the external reading I’m getting where this probe is attached? Gemini says 2x but I don’t trust it given it’s frequently wrong about other things. How hot is too hot? I was seeing temps peak at 480 externally on a small load with the damper as low as it goes during the first burn to cure the paint.
Laser thermometer turned out to be dead so I’m unable to measure the front of the appliance until it’s replacement arrives in a day or two.
Lastly, any recommendations where to set the alarm threshold?
Visually the fire looks pretty good but I’m pretty inexperienced and value your collective input.
Reactions: fao1989
We can tell you that class A chimney max sustained temperature rating is 1000 degrees F. We can tell you that condar sells a thermometer with internal temperature ranges shown below.
But your problem is that you are putting your probe right on the stove so close that even flames could touch it so you're going to have a hard time getting useful information to compare. At that location you could use the stove's temperature ratings, usually 800 max surface temp which would correspond with 1600! inside the firebox.
Are you wanting to know for safety or for efficiency reasons?
I'd start with following the flugard ranges in the attached photo. Realizing that your temps could be a little higher than the ranges because you are closer to the stove.
[Hearth.com] Flue temp measurements, how hot is too hot?
Highbeam,
Thank you for your helpful response. My interest is safety. I’ll proceed as you suggest using the temperature ranges in the image you provided.
Hi FNG47130 and Hearth.com enthusiasts!
I have had a similar question that im still puzzled about. My BK A25 insert has a dealer installed stainless steel flue liner which I understand to be "reasonable" grade stainless steel - as in, good in normal operation to 1000F and a bit higher for short 'surge' periods.
Like you, I was hesitant to pierce the thinnish flue liner 18 inches above the collar which would be the usually recommended location to insert a temp probe. So like you, I attached an [Auber] thermocouple on the exterior screw where the liner attaches to the stove collar. But, consequently, it measures the OUTSIDE temp near the collar, not inside temperatures 18 inches up.
Making use of the wisdom expressed on this forum, I have conservatively assumed the inside flue temps to be *about twice* what I see on my externally attached thermocouple near the insert collar.
Consequently, I think I might have remained OVERLY cautious. I find that the temp at that external thermo couple will hit 490F, with the BK A25 thermostat knob near only 10-20% of max open. So I never run it WOT, out of concern that IF the inside temp is indeed double the outside temp measurement, I might exceed that 1000F.
But this thread, and Highbeams comment have me rethinking this. He noted that, "problem is that you are putting your probe right on the stove so close that even flames could touch it so you're going to have a hard time getting useful information to compare. At that location you could use the stove's temperature ratings, usually 800 max surface temp which would correspond with 1600! inside the firebox."
So I've always wondered, WHY the recommendation to insert a probe 18 inches ABOVE the stove in the pipe? If the stainless pipe or liner attaches to the collar, doesnt it stand to reason that the pipe or liner connection point AT THE COLLAR, would routinely exceed 1000F, if a probe 18 inches higher reads, say, 750F/800F?
In any event, I've often wondered if I am being overly cautious, by interpreting an external thermocouple temp of 490ishF at the collar as near 1000F inside liner temp? Is that a false interpretation? And what does it mean that a stainless steel liner rated to 1000F would regularly be installed to connect to a firebox nominally running at +1000F near the collar?
Regards,
FAO1989
Hey FAO1989,
Had I known this type of thermocouple couldn’t connect in the recommended location with the flexible liner my sweep recommended I would have purchased the magnetic thermocouple and measured stove temp.
Now the plan is to use both the laser thermometer (arriving today) and the thermocouple concurrently to establish how good a proxy the thermocouple in its current location for insert temp. Then I’ll set my alarm level accordingly.
While liner temps shouldn’t consistently exceed 1000F, I’m *assuming* that it’s ok that the internal “collar temp” can be hotter because the collar is fabricated from a much thicker steel. Perhaps a knowledgeable member can answer definitely on that question.
While my plan was to monitor both flue and insert temp I will focus on keeping the insert at a safe temperature which will then result in safe flue temps.
Reactions: fao1989
Hi FNG47130!
"Had I known this type of thermocouple couldn’t connect in the recommended location with the flexible liner my sweep recommended I would have purchased the magnetic thermocouple and measured stove temp."
- I considered an Auber magnetic type, but settled against it because I wasnt convinced it would be any more accurate than a washer connection and screw externally mounted. And I thought I'd read that the magnetism weakens under high heat (?).
"Now the plan is to use both the laser thermometer (arriving today) and the thermocouple concurrently to establish how good a proxy the thermocouple in its current location for insert temp. Then I’ll set my alarm level accordingly."
- I also use a laser thermometer. My experience in shooting the glass or the front of the insert has been nowhere near accurate. There are forum threads on the reflectivity and refraction shortcomings of shooting the firebox or stove with a laser thermometer. It does seem to help with "rising" or "falling". But personally, i dont trust the spot readings accuracy. Will be interested to hear your impressions and experience.
"While liner temps shouldn’t consistently exceed 1000F, I’m *assuming* that it’s ok that the internal “collar temp” can be hotter because the collar is fabricated from a much thicker steel. Perhaps a knowledgeable member can answer definitely on that question."
- Concur that the insert collar is much thicker and therefore manufactured by the makers to handle the heat at the firebox exit. What has me puzzled is the flexible liner connection at the point it connects to the collar. How does that stay below 1000F? If the liner limit should be 1000F, doesnt it seem like the connection point at the collar would exceed that temp directly above the firebox? If as Highbeam suggests 800F exterior temp corresponds to internal1600F at that point, why is the liner not compromised at the collar connection?
Im not yet burning in Virginia. Weather here is delightful. Warm days, cool but not cold at night. But looking forward to a BK fire later in the season.
All the best,
FAO1989
Just so you know the the in flue probes are designed to fit tight, as it heats up the fit gets tighter and completely air tight. The smoke doesn’t want to go out that hole, especially when the stove is going because the draft is physically pulling it up. Lastly on double wall probes the second, outer pipe interface usually has a brass bushing the will expand at a much faster rate and seal the hole even better.
I just put a double wall probe in my PE Summit basement install, happy to use my laser thermometer on a collar screw a few times if you guys want some sort of correlated temps
Reactions: fao1989
Thanks @Turbo89!
I think I understand the dynamics of flue probes in a pipe, as you describe.
But believe the challenge for us insert-owners is that a chimney liner is just a bit too thin to have a probe puncture. The stove-owner's pipes (esp double walled) are more robust, yes? Plus, wouldnt it require dragging the insert out and pushing it back into the fireplace every time you do a liner cleaning iot pull the probe out to get a brush cleaning past that point? At least that was my thinking when I settled on an exterior thermocouple connection at the collar.
Thanks @Turbo89!
Ahhhh, I missed the insert part, yea that’s rough!! I’m not an insert guy, so I can’t offer much help; but I will snag some of those temps next time it’s cool enough for a overnight burn.
Reactions: fao1989
Hi FNG47130!
All the best,
FAO1989
FAO1989,
Auber magnetic probe says it is good up to 750F, I may eventually give it a try.
Initial results with the laser were inconclusive but informative. Wide variation in temps depending on where on the door I measured (door was the hottest surface)…up to 200F difference from hottest to coolest spot. Did not attempt to measure the glass or interior. Measured during temperature ramp up, holding, and declining phases of the burn. Laser temp was between 30-80 degrees lower than single wall sensor attached to the liner collar.
Need several more burns before making any conclusions. For now I’m comfortable gradually increasing the size of my fuel loads and seeing what temperatures that produces.
Will update once I have several more burns.
Weather in S Indiana also glorious…lows in the 50s, but I just open the doors and windows and burn so I can start to get a better feel for the insert. Best Regards.
