iceguy4
Here is the post...I had an ignition problem with my boiler last night. The pellet selection is reduced this late in the season, so I was testing out a cheap pellet I had rejected last season because ... I had trouble with ignition in a cold burn pot. I thought I'd give them a second chance this year but got similar results.
My friend and neighbor Jay Z is burning them successfully in his Fahrenheit furnace and likes them, but they just don't light quickly enough in the PB 105 if the burn pot is cold, IME.
wil lanfear said...
Last spring through this fall I burned Fireside Ultras to heat my DHW usage, I'm now burning Vermont Wood Pellets. The first 3 dip switches, only these 3 to be concerned with, control the quanity of pellets fed into the burnpot at start up before ignition. From left to right I have mine set #1 off, #2 on, #3 on, off is the down position. I don't know what your factory settings are, I have mine set to feed a smaller amount of pellets into the burnpot prior to ignition, fires quicker with less smoke
![[Hearth.com] Harmon PB 105 trouble with ignition [Hearth.com] Harmon PB 105 trouble with ignition](https://www.hearth.com/talk/data/attachments/127/127026-2cc3ff76a34d066f829580da0dcdc013.jpg?hash=R1W7btwrOA)
