Harmon pellet stove auger problems
Fairplaytom
2
California USA
Hi I have a Harmon pellet stove and the feed auger will not work, it works in the test mode so is not the motor just will not work when turned on to run need help on what might be problem
The masses are going to need more information.... Year, make and model of your Harman? Have you followed the trouble shooting guide in the manual? Stove good and clean? Venting is clean and not blocked?
Mal
Mal
This is a Harmon pellet stove model is eccentra sn: 9311 not an insert a free stand stove as stated it works in the test mode so I suspect a pressure switch but not sure
Have you pulled the plates and fully cleaned the stove and exhaust pipe. Likely a cleaning issue
