Looking for some help from those members that have, or have had, my stove model. We have had a fair amount of soot that is inside the firebox. It is all around and not just in one or two spots. It's bad enough that we need to be wearing gloves when cleaning the pot each morning. You can see it on the roof and we brush it off most areas each morning.
The stove works and burns fine and gives us good heat at least I think it does. The soot doesn't seem to change with the different pellet brands we have tried which are about 6. Doesn't make any difference if the stove and vent are freshly cleaned. The 2 air vents behind the grills on the side are free and flapping as they should be. Am I missing any other air inlets? I have tried cutting down the pellet feed rate to a point that it's not worth running the stove from lack of heat. We usually have the feed set on 3.5. The stove is being run on Stove Temp.
I am open to any and all suggestions as this is a PIA. I am aware that soot is usually from incomplete combustion caused by lack of air or to much fuel . The combustion motor has been replaced in the last 5 years or so with not that many tons of pellets being run through the stove. I would guess less then 5 and the motor spins freely without any noise.
