Greets all.
Been burning when it's cool for a few weeks now, trying different things, learning how the stove works. One ongoing issue I seem to be having is getting the stove up to it's operating temperature. I have a brand new Rainier. Here is what I have been doing:
I start with some cut up slats off a pallet, broken into smaller bits to get things going, light those up, once they are burning and the temp gauge starts to move, I load in a few smaller splits and close the door. Within a few minutes those catch and the temp lifts off into the 200-250 area. Once that gets going good I take some larger splits and stuff 'em in there. Close the door and let her go at full air for 15 minutes or so, once the temp gets up around 400 degrees I start backing down the air a little. First to 3/4, no noticeable change in the fire, however the temp slowly rises a little more to about 450. Cut back the air to 1/2, flames still stay about the same, temp climbs to around 500. This is where I get stuck. This stove should hover around 600-650 when it's in it's happy state, but no matter what I do, it won't climb past 500, I've gotten it as high as 525 once, for about 15 minutes and it sank right back down to 500. Clearly I am doing something wrong but I don't know what, I've used softer woods and harder woods, I've tried a few splits and I've loaded it to the very brim. I have tried leaving it at full air, but at full air it gets up to about 400 degrees and won't budge from there, it continues to climb when I knock the air back a bit.
Another problem (that may be related) is that I can't seem to convince a decent secondary burn to maintain for very long. When it gets up to about 500 degrees, if I cut the air pretty far down, say 1/2 inch in from all the way down, a secondary burn will kick in, but only maintain for maybe 15 minutes before it gets smaller and smaller and smaller until it finally goes out and the stove begins to cool, and the wood just smolders until I give it more air, at which point flames appear again.
Even at 500 degrees this stove is working wonders for heating our home and we love it. I am, however, just learning how to operate it and want it to be as efficient as possible. I am hoping the experts here will have some good advice for me, and some insight as to what I am doing wrong.
One thing I have noticed was that one of the fire bricks that are lining the top of the stove is broken, I don't know if it was broken when we got it or not. I know it should be replaced, but how much does a broken fire brick affect the stove? No pieces of the brick are missing, it's just split down the middle. If I need to I'll get a replacement, otherwise, if it's no big deal, I'll get one in the spring.
Thanks in advance for any insight!
-pr0v
-pr0v
