hearth building advice?
NBABUCKS1
53
Wasatch Front, UT
I was thinking of using local beach stone to build my corner hearth. Most of the books on masonry and stonework show people building w/ cultured stone where the pieces stack on each other.
My idea was to use these bigger pieces as the base flat and using the smaller flat pieces and sticking them on the wall with whatever cement is supposed to be used. Each rock is about .75" thick
Is there any good books/websites/articles you'd recommend that would help me? Will my idea work?
[Hearth.com] hearth building advice?
Shouldn't be a problem except for creating a level surface for the stove to sit on.
Good point. The set stones will create an ember barrier, but if the stove specs set a hearth insulation value then that must be met or exceeded. As with the flue installation, meeting or exceeding clearance and combustion requirements is critical.
What make/model stove is being installed?
Sorry I don't get reminders on this.
My stove I am planning on using is the True North 19. It appears you only need protection from embers, but not not any kind of r value.
I have laid down hardibacker on top of plywood. Now I don't know weather to use thinset or thickset. Any recommendation of the morter I should use?
I'd probably elect to use a thickset mortar, like the stuff you'd use for natural tile. I've done a LOT of stone masonry on my house, but not with small stones like that. Your idea will definitely work, but make certain to do like BeGreen said and make a nice, level surface for your stove to sit. maybe set all the stones where the stove would be in thickset at the same time, and use a flat, plywood board and level to tap them all level. After that, you can do a natural, rustic look to the stones. I'm anxious to see this hearth!
Ended up sourcing a bit thiner rocks that are a bit smaller. It's going to be a lot of grouting.
I Ended up putting down a layer of hardibacker over thinset over plywood. On the hardibacker I used a medium set grout w/ a 1/2" scratch coat. It is setting up right now.
I am going to use a sanded grout to fill in the grout.
Any recommendations on a product to seal the grout and the stone?
