I am so happy to find this forum and really need some help.
I have purchased a new wood-burning stove. The requirement is a hearth of 25 inches in order to have 18 inches in front of the fuel door opening. It requires a hearth R-value of 1.1, so I plan to use 1/2-in Micore 300, then 1/2-in Durock, then Tile.
I would like to extend my hearth from the existing 19-in to the required 25-in by removing 6-in of the subfloor in front of the existing hearth. I have already removed the existing hearth stones and cleaned up the (fairly soft & crumbly) cement residue underneath them. Underneath the cement residue is a firm concrete base which is part of the fireplace construction & is in fine shape. It forms the floor that the hearthstones were set on and it measures 19 x 60-in. The subfloor is 1 1/8 inch plywood which stops short at the existing hearth area.
I crawled under the house & can see that this concrete butts up to a 4x6 girder that is set on pier blocks & posts. So, if I removed 6-in of the subfloor, it will expose the surface of the 4x6 and an additional couple of inches. I found a post at the John Bridge forum where Gooserider, CX & Rose are discussing beefing up the floor joist area in order to extend a hearth in this way, so I know that would have to be taken care of. I understand that Gooserider has had an accident and has not been a part of this forum for quite some time now; I wish he & his family well.
If all this was done, there would an area in front of the fireplace that measures 26 x60 & is recessed 1 1/8 inches below the surface of the existing subfloor. Once the 3/4-in hardwood floor is added to the subfloor, the hearth area would be recessed a total of 1 7/8 inches.
My question is: how can a hearth be constructed in this space which meets the R-value, provides adequate substrate for the tile in a way that does not transmit a crack to the tile surface where the wood 4x6 and concrete meet and is not above the surface of the hardwood floor. Or, if that is not possible, to keep the height to a minimum. There is the complication of the fact that the working surface would be made of dissimilar surfaces (existing concrete and 4x6, etc). What could you use as a substrate for the Micore/Durock/Tile that would make sense & not transmit a crack to the tile surface due to the disimilar surfaces underneath (concrete & wood). I read in this forum about using deck mud with lath over a moisture barrier like roofing paper. It said the mud should be 1-in thick to do that. But they were talking about putting the mud over a plywood subfloor (which is not what I would have). Would that even be an option for me? If I did use 1-in of concrete, the hearth would be about 1-in higher than the finished floor (after hardwood floor) & I might need to raise the level of the firebox floor a bit so that the stove sits level. Is there a way to provide adequate substrate with another product that is thinner and that would protect the finish tile flooring from cracking due to the dissimilar surfaces below the tile installation?
I hope someone has an answer for me; my brain is in a knot thinking about this. I love this forum.
Thank You, Bend
Thank You, Bend
. Would it be ok to fit the cement board to the firebox floor tightly so it wont move and stack it up so it is approximately level with the hearth. Or do I need to screw it down & cement the layers together with thinset? Is it necessary to tile over it? Or could I use a piece of 1/4-in metal as part of the stack for weight disbursement/stability under the stove (use the 1/4-in thick metal under the thinner .26 gauge for sliding in & out).
