Okay, I'm getting ready to build a hearth for a Englander 13nc I just picked up and it requires floor protection of at least R 2. per the manual. I've been reading everything I can find on here and elsewhere on the web and this R value stuff for a hearth is confusing with a lot of conflicting info. Anyway, it seems the consensus is that the surest thing is something like the Micore 300 board put between some layers of Durock or Wonderboard. The Micore is near impossible to find and potentially expensive when you do.
Apparently you can order it here: (broken link removed to http://www.mantelsdirect.com/Products-Accessories/Marble-Granite-Slate/MC300-Micore-Board)
There's lots of discussion of just using sandwiched dead air space with steel studs between layers of Durock. The issue is no one seems to agree anywhere on the R value of the air space. I think I'd just assume go this route as I could get all my materials locally and it'd be cheaper but calculating the R value seems iffy. Best I gather is the R value of a dead air space of at least an 1" is about R1.
What does anyone think of pouring some vermiculite in that air space with the steel studs? Seems that'd be a cheap way to definitely bring the R value to at least 2+ easily?
