Hello all,
I am desperate to find hep with an issue I just came across on my fireplace. It’s over 40 years old and The hearth is moving forward and the bottoms 3 rowes Of bricks on one side of the fireplace wall have Cracked and dropped almost 2 inches. The crack goes across along the side of the hearth. The right sided is not as bad but still has cracks and loose bricks and mortar failure which I know isn’t uncommon. But there is also crack That runs from one side and goes across the hearth under the insert overhang where it meets the fireplace.
we are on ground floor with concrete foundation so it’s not a support issue and the wall portion is not attached to the actual chimney as far as I can tell. I’ve yet to check the outside chimney but I can’t see any cracked inside the fireplace in the void areas beside the insert where it sits in old fireplace
Initially I was thinking I could remove the hearth but i will need the insert to be removed as I am pretty sure the overhang sits on the hearth so that may be a different issue all together.
any help or feedback on the hearth and the best way to sort this out, would be greatly appreciated!
thanks
T
![[Hearth.com] Hearth SOS [Hearth.com] Hearth SOS](https://www.hearth.com/talk/data/attachments/264/264682-d51f57eaff7b120caca8d3998f93b006.jpg?hash=dWXsaDtitr)
![[Hearth.com] Hearth SOS [Hearth.com] Hearth SOS](https://www.hearth.com/talk/data/attachments/264/264683-ad752ce3939d8ec7e6a0db03855d3ca3.jpg?hash=0QyfmaZHfi)
![[Hearth.com] Hearth SOS [Hearth.com] Hearth SOS](https://www.hearth.com/talk/data/attachments/264/264684-8e5b4c538e3a72c0df209b60c3944ad5.jpg?hash=oL4lylTBYz)
![[Hearth.com] Hearth SOS [Hearth.com] Hearth SOS](https://www.hearth.com/talk/data/attachments/264/264685-4a4e34e8704b0dc5b22f2b76d3ea3886.jpg?hash=0PEE5ZmABQ)
![[Hearth.com] Hearth SOS [Hearth.com] Hearth SOS](https://www.hearth.com/talk/data/attachments/264/264686-38848966ce307d01e46deb0c096642e6.jpg?hash=Y95gP_9Oxv)
thanks
T
![[Hearth.com] Hearth SOS [Hearth.com] Hearth SOS](https://www.hearth.com/talk/data/attachments/264/264687-1364c849d6b3c6bb5d9a7b3d60723930.jpg?hash=nTtNrt7AWu)
