Hello friends, I'm renovating the flooring around my fireplace and found some issues with the concrete pad and subfloor. It looks like the subfloor settled over time and separated from the brick that was installed on top of the concrete pad. The pad itself is also ~1/2" higher than the subfloor.
I'm planning on installing porcelain wood look tiles on schluter ditra laid over the plywood so I have to level this area out. I don't want to raise the subfloor up with concrete board because I'm installing ~600sqft of tile and the height of the floor is a concern. Can I get away with filling the void under the bricks with some backer rod then taking a grinder to the pad and leveling it down to the subfloor? I looked at the joists under the fireplace and they're in great condition, no signs of sagging. The floor should support the tile, I calculated the deflection to be L/427. Any thoughts or feedback would be appreciated, thanks!
Joists:
Joists:
![[Hearth.com] Hearth to subfloor interface [Hearth.com] Hearth to subfloor interface](https://www.hearth.com/talk/data/attachments/292/292061-b639b921e80bced07a54c649da871e86.jpg?hash=k-UoPqdtee)
