Hearthstone Clydesdale Install with Pictures
spacecowboyIV
129
Central VA
Hello all, I have been searching this site for a while to gather information on a wood stove / insert install. I decided on a Hearthstone Clydesdale insert and got everything (almost) ready to go. Here are some pictures of the first break-in fire and the install before any fires. The inside was almost too pretty to start a fire on those soapstones.
http://lh6.ggpht.com/_0gPF0Wi78-A/TMLgYfveSnI/AAAAAAAAABE/vhsO4O-cvQI/s800/IMG_0773.JPG
http://lh6.ggpht.com/_0gPF0Wi78-A/TMLgYuQlwdI/AAAAAAAAABI/rz4_gP3NO4g/s800/IMG_0774.JPG
http://lh3.ggpht.com/_0gPF0Wi78-A/TMLgZMuQi_I/AAAAAAAAABM/u-4nllaZjJY/s800/IMG_0777.JPG
Welcome to the forum spacecowboyIV. That thing looks like it should crank out some serious heat.
Do you plan on cleaning up the blackened brick? It shouldn't be too difficult to do.
Good luck.
Hi I work at a small hearth store. Can you tell me if the top of the insert that sits out onto the hearth get's hot enought to cook or use a steamer? We just started selling Hearthstone and I have been wondering about my clydsdale we have on display. The other question is how far can you open the door on yours? Our door only opens about 45%. Thank you.
who is your sales rep?
they should be there to educate thier dealers
OP,
great looking stove! id like to see a picture with the surrounds on :)
Thanks for the great remarks, the surround will be added shortly. I plan to put tile over the brick to make things look a bit cleaner (slate or ceramic?). Years of use as on open fireplace has made it a little rough I know.
Is that really soapstone inside the firebox?
sweet!, I have never seen soap stone inside of a stove like that before. How is soap stone compared to fire brick?
Looks great. Those Clydesdale's have a nice big view of the fire.
Here are a couple pictures of a Woodstock stove so you can see the interior with soapstone:
This one shows the cat. The cat is at the front of the stove.
And here is a whole stack of soapstone ready for building:
btw, the Woodstock stoves are soapstone and they also use some firebrick.
Firebrick is suppose to only protect the firebox and does not retain any heat from what I understand. The soapstone is suppose to retain the heat and release it after the fire goes out. Hearthstone claims 2 additional hours of heat after the fire goes out, but I haven't had a hot fire yet to test it out (we're in the 70's here this weekend).
damn, that woodstock looks like a cadillac compared to my Jotul Oslo....nice looking stove!
Congratulations on the insert Spacecowboy!!
You will get a boat load of heat out of that beast of burdon. Forget about cooking on the clyde it ain't designed for that,, If your fireplace is exterior facing a block off plate and covering the inside of the firebox with heat rated insulation helps. All that masonry acts as a giant heat magnet right to the outside without one.. Blocking off the flue and insulating the fire box will drive a significant amount of heat into the living space versus loosing it to the outside..
Great looking insert if I do say. Your giong to love the long burn times. Install as far foward as you can. For me it made a noticeable differance
What did you use for insulation and how did you insulate. I covered the back and sides in ceramic blanket insulation and the block off plate (see the white in the pictures, stuff now goes all the way around the sides of the fireplace).
