Is there any reason why the top burn tubes on the Hearthstone Heritage slop from front to back? Makes it difficult to load.
Really, its just that the firebox is too small. You would never notice that sloped roof if the stove was twice as large.
being you had the stove maybe you can help me ....i load the stove raking coals forward....loading bigger splits in the back and then smaller ones in the front ...issue i sometimes have is to much coals that block the air from coming in the front...any suggestions? to many coals?
I owned the stove as well. I liked it a little more than Highbeam. I thought it was a good stove for a well insulated 1500 sq ft home in a colder climate or under 2,000 sq ft in a milder climate.I know you had the stove that i have now...the firebox is to small...not sure the stove is big enough for the 2400 sq ft i have to heat with it...max burn i get out of it is 7-8 hrs and that is if i'm lucky ...I know i have asked you in the past but what was your overall view of the stove?
I liked the stove just fine but I was able to conclude that it was never designed for a long life of daily burning. It was a very attractive stove with a great fireview and performed per the specs. Really shoddy door latch systems.
ridemgis is right about moving the coals to the front but also digout a small channel to allow that airjet to blow. Really though, blocking that little doghouse hole might be a benefit since it reduces the air supply and might extend the burn. The primary air mainly comes in from above the glass and PLENTY of air comes in to this stove if your chimney is reasonable.
The stove is old and the more that I look at it the more things I start to see that are going wrong with it. I have replaced both front and side door handle, the front glass, front glass gasket, the front door itself, the side door gasket, the ash door gasket. I noticed that the front door frame is starting to seperate from the stove slightly and I can't tighten back up. I know the prior owners put the stove in around 2002 so it is 11 years old now. what is the average life span of this stove?
I hear ya brother. I've owned my Heritage for about 6 years and I hate it. It looks great, especially when you rear vent it, but the quality is terrible. I've replaced the front door frame once the cast broke. Luckily Hearthstone replaced this door frame with a latch channel that was not cast, but a steel plate in it's place. Both door latches, however, have been worn down until they are paper thin and eventually break. There is not a positive fit when I close either door. I am scared to death to put any kind of load in this stove because there is just no way to control the burn with the leaks and I'll be damned if I am going to put anymore money into it.
I have decided to get a Jotul F 55. A little bigger than I need, but I tend to keep my 2400 sq ft house on the cool side. It might be nice to see what 72 degrees feels like. I also like the combo construction - steel firebox with firebricks, but cast iron sides. The best of both worlds in my mind. Also, it eliminates the ash box, the top load that the F 50 had and it is 100 pounds lighter than the F 50.
What is the price for that stove? I can't afford to buy a new stove right now. The one I have works ok but I don't like it overall. think i am going to start writing things down that I don't like so I know what i would want in the next stove.
I also just realized I am not far from you. I live on the north side of chadwick lake.
Not sure on the price, but Jotul advertises it as an affordable, simple stove with many improvements. I would hope it would be under $2k.
I live by the Mohonk Mountain House.
Yeah i know where that is. Nice looking stove. Can you side load that stove? Not sure I want to be opening the front door all the time.
