Replace Jotul 3CB with used Hearthstone Heritage (non cat)?
John Lehet
351
Vermont
We've been heating with a Jotul 3CB that I got used about 12 years ago. And a Hearthstone Heritage has come up for sale in town. $800. The Jotul had been rebuilt when I bought it (which I think meant he replaced the baffle), but I don't think the internal iron "fire brick" parts were replaced at that point. I rebuilt it (baffle still perfect, as it is now) about 6 years ago, including the inside castings. It's in good shape now. The Heritage seems to be in good shape, but I haven't inspected it.
I could probably sell the Jotul for at least the price of this used Heritage?
The Jotul is the best stove I've ever had in 50 years of wood burning here in Vermont, except a decade plus with a masonry stove in a very different house. This chimney stays clean (except for a layer of fine soot) every time the sweep comes every other year. I burn about a cord of a half of wood cut two years previously and stacked in a shed with walls and air openings. Starts easily, burns clean, warms up pretty fast usually.
This is in a "great room" 28 x 28, which was a one room schoolhouse built in 1860, in Vermont. It now has a lot of windows and 2x4 wall fiberglass insulation and a high ceiling. We added a mini split to this room 5 years ago, which carries all the load in shoulder seasons and can help a bit in the real cold. We've done about all we can to retrofit insulate, but short of tearing the walls down there isn't any more we can do.
Chimney is interiour brick with an 8" round stainless steel liner, really pulls hard, especially once warm.
The mini split has changed the way we use the stove. Used to heat fall-winter-spring with wood, but now it's more like hitting the stove hard in the real cold, bring the room temp up for morning coffee and evening after work in real cold. Or make a little fire to make it cozy -- mini split is not cozy comfy, but background warmth. Previously I didn't want a more powerful stove particularly, because I didn't want to overwhelm this space in shoulder seasons and burn the stove cool. Now, when we need the stove, there's no worry about that, real cold weather use or the small cozy-making fire. (Of course lately in Vermont we haven't had anything like the hard winters we used to have. I've planted peach trees, which are thriving. You couldn't keep a peach tree alive for long a couple decades ago. But with the unstable polar vortex you never know, could get some real cold. Not last winter.)
End of the workday in real cold, fire up the Jotul to take the chill off for the evening, let it go out overnight. On a cold morning fire up the Jotul for breakfast, let it go out for the mid day unless it's crazy cold. So clearly the Hearthstone might be sub optimal for our use pattern, and I'd have to keep it going more to keep it warm, use more wood and less electricity, use the mini split less.
So the downsides of the jotul are that I don't want to overfire it, it's a bit hard to control in serious cold, and it's just barely enough heat in the very coldest weather. I mostly have to be careful not to put too much wood in it if it's 0F or below. Like I said, my chimney pulls hard and my wood is as dry as can be. If it's burning hot and the chimney is pulling, it's going to really burn. (In rebuilding it I saw that the air control can't fully shut down below about maybe 15% open, it seems). At some points I have to be careful not to put too much wood in the firebox, when the stove is hot and full of coals. Sometimes at the end of a cold weekend day I can only put a small split or two at a time as it has built up a pile of hot coals and also will really take off if I fit a couple of bigger splits in over the coals. Could use a but more heat on those coldest days. I could backfill with the mini split in the real cold, but the heat pump is only a 15K. Also have oil heat in here but try not to use that -- and the oil by itself won't keep up with this room, not enough radiator for all this heat loss. I've been rather stubborn about not supplementing the stove with the oil, but thinking about it now it seems like a better situation than overfiring the Jotul and ruining it.
Advantages of the Heritage would be probably more maximum heat output in the real cold? Cruising along through a cold weekend. It would look good against the granite slab behind the stove and the soapstone hearth (I scored some old salvage soapstone lab counters and made a hearth out of them). Also have soapstone kitchen counters.
Disadvantages would be that it might rather suck for our favorite use case: bump it up a couple degrees quickly and take the chill off while we drink coffee or eat supper sitting by the stove. I've read here about the latches and hinges on Hearthstone, so that's obviously a downside. I also understand that our use pattern isn't great for the Hearthstone.
(40 years ago I built a soapstone Tulikivi masonry stove in a superinsulated house, lived with it for a dozen years, burned little poplar sticks, half a cord a year. The tulikivi was one of the first ones imported into the US, sort of a trial run, so I got it for a steal. Needed a small bit of steady heat in that little R38 house, and it was perfect. Very different world than my 1860 schoolhouse! So I understand thermal mass stoves. The hearthstone is probably like a tin can compared to the 3500 pound Tulikivi, but a lot bigger a flywheel than the Jotul.)
I'm a spry 60-something year old, cut and stack all my own wood these days, though at some points with back or tendon injuries I've had to buy cut split and delivered and even pay people to help stack it. Doing OK this year, but really my goal is to burn less wood and not more.
I have considered upgrading to a more modern and bigger iron stove, like a new Jotul, at times, but financial security is at an all time low this year. Wife is a healthcare worker at the VA, and oh boy. The healthcare infrastructure altogether in Vermont is on the brink of collapsing at this point, and the VA, oh dear, so healthcare workers like my wife, main breadwinner, are kind of on shaky ground here right now. Worst case scenario layed out in some analysis is that we lose 18 hospitals in the state and several clinics too, under the new cuts. I'm a starving artist by trade, and my sales are a lot slower in the current economy. Probably should keep the old Jotul and rebuild it as needed as long as I can, right? The used Heritage would be probably a break-even financial move I guess but I’m guessing I’d burn more wood.
Sell that jotul ASAP. Personal opinion I’ve heard to many issues with the Hearthstones.
I have an F400 up stairs and a 2.4 cu ft Drolet downstairs.
How tall? 8” will be difficult to control anything if it’s over 15’ cold and windy. Install a key damper.
Take a look at the Drolet products and Englander (parent company is SBI and has a good reputation )
That one might be too big but better bigger than smaller for the real cold days/nights.
Reactions: MRD1985
Why sell the Jotul ASAP? Because it’s hard to control? Because modern stoves are better than the 3CB?
Also I think my flue is actually 6”! It’s pretty tall though. I don’t know exactly how tall it is, but I’ve been up to the top of it on a ladder (I used to clean it but my wife wants a pro, doesn’t want me up there). I get really heebie jeebie up that high, is how high it is, and I’ve spent a fair bit of time on high ladders!
It sounds like the Jotul is a bit undersized and the Hearthstone would probably be a better fit but I’d be Leary of one going for $800, may need a lot of work. Doesn’t hurt to go check it out though . I’ve seen a couple used Heritage for over $1500 around here that were decent shape.
$800 Hearthstone, the guy says he bought it used but has never used it himself. He’s now going for a propane stove, I’m guessing he’s aging out of wood burning. He said he had it thoroughly checked out by a professional and it’s in good shape — but don’t know who checked it out. One stone is cracked on top and sealed back together with cement, maybe over fired at least once. Haven’t seen it in person.
Minor quandry as the stove sure is pretty and would fit in well on our hearth and maybe have more BTUs, but I keep reading things like it takes a half hour/45 minutes to get any heat out of it at all. For the afternoon fire that would be OK. I can start the fire earlier. Morning fire, that would suck.
This all does stir up a bee in the bonnet to get a newer and maybe more modern stove, but then we are in tight belt mode. There’s a nice blue enamel Jotul F400 about an hour and a quarter drive away on Craigslist, would be an upgrade for sure. And I do think my Jotul is probably worth about $900, so not a bad delta.
Reactions: Todd
Steel stove throw heat fast! I get the Hearthstone is a good looking stove. $800 for used stove with cracked stones a bargain.
If money were no object I’d choose a Pacific Energy T5.
Reactions: Todd
I owned the hearthstone heritage noncat and it is a good looking stove but slow to heat up and not durable enough for regular use. You know what you have with the jotul.
Reactions: Todd
I’ve seen decent shape F3CB go for over a grand. I just sold a 602 CB for 1200
Reactions: TreeCo
Thanks everyone. I think I’ll not go for the Hearthstone. It got me thinking though…
The F3CB is a great little stove. The Heritage will provide longer burntime and a different, softer heat than the radiant heat. Perhaps the thought is that now is the best time of year to sell. The market for used stoves is strongest in Sept-Oct.
I have to throw a shout out for the 3CB. We’ve been using ours as the primary heat source for nearly 30 years in our smallish CT ranch. It’s a bit undersized but we have a small pellet stove to balance things out. Fortunately the old CB3 has a full air intake adjustment and burn control is smooth. We burn 2+- cords a season. Never had to change a plate or baffle, just gaskets. Did replace all the interior nuts and bolts about 10 years ago. This stove has been most trouble free appliance I’ve ever owned. $700.00 new with factory spark screen for open door burning 🔥. I’d bet they don’t make them to last like this anymore 😗
Reactions: Todd and EbS-P
Did you get the heritage? I would have gotten the f400. You would like it quite a bit more than 3. I went from a jotul 3 to the f400 and it was 100% better than the old 3.
Reactions: Todd
Agreed, likewise here. The F3CB is a great little stove, but I like the design and air control more on the F400 as well as the increased capacity and big fireview.
Reactions: bigealta
And...... Cutting and stacking 18"-19" pieces vs 16" pieces might not sound like much of a difference but for me 18"&19" splits are a much better size to cut, stack and burn.
I’ve had the Progress on order since 9/9. They can’t ship it yet, until EPA gives them the cert for crib wood testing. That’s been Any Day Now since before the government closed down for six weeks. I’m hoping it’s close.
Having researched not very much at the time and then seen a lot since, I’m really glad I didn’t impulsively buy that pre-cat Heritage.
The 3 CB has been burning through quite a lot of wood so far, mostly very dry black cherry at the front of the wood shed. It’s really fine, even if I do need to run the mini split at night. On Thursday night though the temp will go down toward zero F. That’s when things get a bit hairy with the little Jotul. Also when it’s cold I miss the ability to keep a fire overnight. Thursday night will be running the mini split and some oil heat as well, once the Jotul loses the fire.
I have a whole lot of wood stacked for next year and the year after at 19” to 21” with the progress in mind. (I’ve been busy with the chainsaw). If the Progress doesn’t come through for some reason, like the EPA just won’t give them the cert, I’m going to have to find something with a longer firebox.
Reactions: TreeCo
