Here it is.Where is the burn time claim on that model? I must have missed it
The idea that heatlife, given how they define it, and burn time are equal seems counterintuitive at best
They give a range of btu for epa testing. The low end I'm assuming is air shut all the way down. Is the max btu with the air all the way open? Wouldn't that damage the stoves especially soapstone stove?
That’s the available range of safe and clean outputs. Bound on the bottom by cat stall and pollution, bound on the top by stove material limitations and design.
The numbers aren’t perfect. Epa screwed up by adding the crib wood or cord wood option which makes comparison impossible unless they both use the same option.
Yikes good catch. That’s a bit mind boggling to me. That would suggest hearthstone in a hybrid design is getting better burn times than basically anyone including standard cat models. Seems highly improbable but would be very impressiveHere it is.
Not to de-rail the discussion here but to the same extent one stove was tested with “mostly maple” and another with oak. Hard to get an apples to apples it seems
Good luck with your new stove. If you get a weel made one, you will love your stove. If the stove is brand new, would you please take care on how the new doors open and close, I mean how smooth the lever action is, not comparable to other stoves systems. And it's that smoothness I try to bring back on my 2 Hearthstone. That butter like movement disappeared very fast on mines and it was impossible to get it back, I tried many many times to remove all the latch parts, cleaned them, lubricated with HT grease, removed/ add washers but all I got is a metal on metal rubbing/grinding feeling.Well, I'm off to pick up my Heritage TruHybrid. If anyone wants specific pictures, dimensions not called out in the manual, etc... let me know.
Nice to hear that, in fact the enameled black is very nice. Maybe your draft is too strong, have you tested the chimney draft with a mamo?Well, my initial reports on my Heritage TH is that it's a beautifully made stove. Very tight assembly tolerances and everything seems very high quality.
I seem to over-fire the thing constantly, even with the primary air control at its minimum.
I'll start a new thread for details.
Make sure the front door rope gasket is not hardened from the liquid used to hold the gasket in the groove, I had to replace the gaskets on my Heritage and Castleton one. Hope to see the 25 number soon ! Good luck .I am going to get a Hearthstone Castleton TruHybrid sometime this week, I still need to install the Chimney and everything so im hoping I will have it 2 or 3 weeks from now.
I will be sure to update on this thread about my experience with the "25 hour heat life" lol!
Do you have a on top of the stove thermometer ? Very important .Well, my initial reports on my Heritage TH is that it's a beautifully made stove. Very tight assembly tolerances and everything seems very high quality.
I think a more accurate statement is it will take 20-30 minutes before the stones start to heat. "Heat up" to warm is more like hours. Soapstone is an insulator, not a conductor. You need to drive enough heat at the stones that you overpower the insulation and let heat into the room. If there wasn't a glass front on the stove it is likely you would feel the stove never put out usable heat. I think that most of the heat in the room I get is through the glass door.I saw a USA Hearthstone dealer on videos saying that soapstone takes about 20 to 30 minutes to get warm but keeps the heat longer, about 2 hours longer.....
The stone definitely takes some getting used to as far as how long it takes before you can start feeling heat from them. What's interesting is that the dealer I bought mine from never went over anything with me on the characteristics of this stove. I can have the flue and catalyst temps up to where I want them long before the top stones get warm enough that I cannot lay my hand upon them. The dealer had a 4"x6" piece of the 1-1/4" thick soapstone and I couldn't believe how heavy it was. It's a very interesting material.
I wonder how many folks are initially unhappy with them if they've came from a cast unit, then if anything is damaged from over-firing and they get a bill...
I came downstairs this morning and the stove top was 179*F. At least we can stay somewhat warm when re-lighting that fire.
I will use brake tubing . What do you mean by : higher than the port ? Thanks for the infos.You can put your gage wherever, but I would install it higher than the port so any condensation can drain (in industrial settings we commonly use double ball valves below a loop in order to drain off condensation traps without exposing the process piping to atmosphere). Just be sure to precisely level the manometer.
What are you using for tubing?
![[Hearth.com] Hearthstone truhybrid [Hearth.com] Hearthstone truhybrid](https://www.hearth.com/talk/data/attachments/273/273443-2b65ad9db9a03c73262aeebc1fcd4eff.jpg?hash=UIapidK2mk)
I see what you meant. Sorry for my poor Français Québecois . ThanksThis isn't my picture but it accurately displays what I meant to communicate.
The port his manometer is hooked up to (a yellow arrow is pointing to it on the side of the stove) is physically lower than where his gage is mounted up on the wall. This way, if any condensation were to be generated in the tubing, it will drain back into the port rather than into the gage if it were mounted below the port.
Generally speaking with short runs of tubing, since you are measuring negative air pressure you don't need to worry about placement of the gage because as long as the tubing is leak-free, the pressure at the gage will be equal to the pressure at the port.
As far as the location to drill the port, again it shouldn't really matter as long as it is placed far enough away from anything that will generate turbulence in the flue stream like dampers or elbows. 6-8" above your stove connection should work just fine.
![[Hearth.com] Hearthstone truhybrid [Hearth.com] Hearthstone truhybrid](https://www.hearth.com/talk/data/attachments/273/273445-d670ccf27de2f4f4e77d337831f85f52.jpg?hash=XYt63sZkcD)
Thanks OH_Varmntr, in fact if the stove had only one handle it would be ...probably OK, but there are 3 big handles plus the air control knob to catch the look and that dont matche the beauty of the stove itself. Only my/and my wife opinion. If you take a closer look at the air control knob (also in black) you can see on the photos 2 white dots to indicate the air adjustment from the closed position, much easier to fine tune the air feed rate.Yes that definitely improves the width of the primary air burn channel. I really like that!
I also like your painted handles, it looks much better that way.
