We recently moved into a new home. The wood burning fireplace is a Heat & Glo Rutherford, and while we like the styling, we’re having trouble with smoke getting into the house (the house is very tight as is required with the new building codes.) We’ve had a number of wood stoves and wood burning fireplaces in previous houses, and know about burning dry, seasoned wood, not running exhaust fans, cracking a window, etc. The flue is twenty-three feet from the top of the firebox to the top of the chimney, straight up. We like to have an evening fire, but don’t really expect to heat the house, or even the room it’s in.
My questions are:
Is the Rumford design prone to “leaking” smoke into the house?
It looks like while the outside combustion air enters the outside of the firebox near the bottom, it vents to the interior of the firebox near the top. Is that to help cool the firebox surround? That seems like an inefficient design.
We didn’t realize the fireplace doors don’t seal like the Xtrordinair in our last house, is there a way to retrofit sealed doors?
I’m assuming a chimney fireplace exhaust fan would solve the issue, does anyone have any experience with those and a brand recommendation?
Thank you.
My questions are:
Thank you.
![[Hearth.com] Heat & Glo Rutherford "leaking" smoke into house [Hearth.com] Heat & Glo Rutherford "leaking" smoke into house](https://www.hearth.com/talk/data/attachments/318/318961-97314725b6e14aad923b16c2317ddd14.jpg?hash=f4Zy9KbV0w)
![[Hearth.com] Heat & Glo Rutherford "leaking" smoke into house [Hearth.com] Heat & Glo Rutherford "leaking" smoke into house](https://www.hearth.com/talk/data/attachments/318/318962-474048662b1be9e82a3ffd563333129c.jpg?hash=ILrMwpgWyj)
![[Hearth.com] Heat & Glo Rutherford "leaking" smoke into house [Hearth.com] Heat & Glo Rutherford "leaking" smoke into house](https://www.hearth.com/talk/data/attachments/318/318966-212542213e4947c43c534ed7186986d8.jpg?hash=YxyFB4uLIX)
![[Hearth.com] Heat & Glo Rutherford "leaking" smoke into house [Hearth.com] Heat & Glo Rutherford "leaking" smoke into house](https://www.hearth.com/talk/data/attachments/319/319009-e897e4e7bf3a8c1e6fbcf08870b51c43.jpg?hash=qPd4RWV2n0)
