Some of you have far more experience than I at calculating heat loss, so I'd like to request help here-
I pitch in with the upkeep of a former one room schoolhouse that is used for various gatherings-- it's heated only on a "per event" basis.
The cellar has a sectioned off "pump room" that contains an iron jet pump, tankless water heater, etc. That space is 7x7 ft with a 6 ft ceiling. Walls are framed with 2x4s and homasote sheathing, and at least _were_ insulated- though I suspect that rodents have made off with much of the fiberglass. Floor is dirt.
The pump room has been kept from freezing to date by a wall-mounted electric resistance heater with a fan in it. That heating unit is old and decrepit, and I've suggested that we replace it before it fails.
I've also been thinking that perhaps we should choose a new heater that does not rely on a fan- such as this radiant unit:
http://www.mcmaster.com/#1991k77/=43eja3
I'd like to "size" such a heater so that we can be certain that it can keep the room from freezing- but not draw more power than needed.
Can some of you who know your way around heat loss calculations in your sleep please give me some input-- and also, if you can, while you are thinking about it, also a way of then going from Btu/hr to watts with such a radiant heater?
Oh- and while I'm picking the Boiler Room's collective brains- anyone ever run across a product in the nature of an "engine block heater" but instead intended or adaptable to placing on a cast iron jet pump as a "freeze prevention device in case all other heat sources somehow malfunction?"
Thanks!
Thanks!
