Heat N Glo Tiara pilot light and ignitor not working
LAndrim
99
Outside of Philly
Hi Everyone...can someone help me with a pilot light that will not work on TIARA II?
When I press the pilot light switch ink it started "clicking" a few times, then died...any insights? Thanks much!
Clean the rectifying sensor in the pilot assembly with steel wool & also check the ground wire connection to the stove body.
Make sure the screw is TIGHT.
Thanks Bob,
I gave the sensor a good cleaning with steel wool and a small brass brush...I also checked the ground wire as you suggested, as well as all the wires, and found a battery compartment with a AA that has been in the stove since I got it 10 years ago!
Replaced the battery and my pilot is on!
Thanks much for you reply! Stay warm!
Jamie
Reactions: DAKSY
