I just finished my first burning season at my new home with a Jotul 3cb, which I moved from my old home. At my new place, the stove pipe runs through the interior of the house, straight up and out, for a length of about 28 feet. I had a serious draft and the stove glass never got black throughout the entire burn season even though some of the wood had (what I would guess to be) a high moister content. This leads me to believe I had a little too much draft and my burn times were shorter than in my previous home.
I was considering adding flue damper to slow down the draft. My question is, do you think this would increase the heat output of the stove? Am I losing too much heat straight up the chimney? I constantly monitor my stove top temps and keep them between 400-550, but I feel I wasn't feeling the heat like I used to. I know that based on the placement of the stove, a lot of heat is running upstairs, but this was the only feasible location for the stove. Do stovetop temps directly reflect the heat output that you feel from the stove?
Any opinions are appreciated, thanks John.
Not opening the damper during re-feed was not an option for our rear-exit 3CB.
