I hope it works out well for you, our next dryer will be a HPThey've been around for a while now.
We have the LG ThinQ model and are happy with it thus far.
It replaced a series of 3 Bosch condensing ventless units that we had bad luck with.
Our experience is that the technical challenge is removing the lint so that it doesn't clog the heat exchanger. Maintenance with the Bosch units was recurring and challenging. and they seemed to have a critical flaw in the way the drum was constructed.
The LG unit seems to have a better design with two easily accessible lint filters but time will tell.
The smaller size is not an issue for us as we hang larger items out on a clothesline.
Our HP clothes dryer is located in the same room as our HP water heater so we're hopefully capturing that 1000w for water heating.Heat pump dryers are pretty common in Europe, Switzerland even banned the sale of vented dryers back in 2012.
Keep in mind a heat pump dryer is not like a heat pump hot water heater, they don't remove heat from the house, they actually add it due to their ventless nature. The power input to the compressor (about 1000watts) ends up in the room, which would add to the cooling load in hot climates.
Ah I had no idea these were all ventless with no option for vented, but I guess it makes sense. Here is a study meta analysis that actually goes into some minor detail about the process. The main advantage is capturing some of the heat out of the waste stream and recycling it in the process. Hybrid heat pump dryers with standard electric heating elements along with the heat pump came out to be the most efficient. The median payback period on the energy savings from one study mentioned was 22.1 years. The one trick they seem to miss as far as I can see - they did not compare them to unvented operation of standard electric dryers where the process heat is also recaptured at basically 100%. The bonus over a standard dryer in that case would be very low, most likely zero. Since most people only operate dryers that way in the winter, it would at least have a part-year efficiency bonus in most installations.Heat pump dryers are pretty common in Europe, Switzerland even banned the sale of vented dryers back in 2012.
I'll let you know in about 14.5 years.If you can hang laundry out I don’t see these as really a good financial investment. I see the ventless aspect as the biggest selling feature. I want to see average cost of owner ship for 10-15 years.
As long as your heat source that is providing the energy in the house is cheaper than the electricity or fuel to run a normal DHW or dryer it's good in the winter too.
This is not completely correct but I see where you're coming from. If you want to heat with a gas hot water heater, it's going to be vented and not 100% efficient. When you heat your house with gas and use a heat pump water heater, and if you need 3000 BTU to heat a certain quantity of water to a certain temperature, you will use the heat from the room at the coefficient of performance + heat generated in the compressor cycle = 3000 BTU, no energy is created or lost in the process, it either goes into the water or back into the room, which goes into the water, 100% of the energy used and moved stays in the house, nearly completely contained in the water. In your example, which was COP 2:1, 1000 BTU of electric heat ending up being used would only scavenge 2000 BTU from the home to do the same work of 3000 BTU of heated water... When you compare it to a vented appliance, you lose some % of the energy needed to the exterior of the building, whatever the efficiency of that appliance is rated, and you will always lose at least some energy to the vent. So in the vented appliance, you use 3000 BTU + losses in the water heating process.Depends on how you want to look at it. Let's suppose your primary heat is gas. You are first going to put 3000 BTU's into the heating space and then use about 1000 BTU's of electric to move it into the heater. That's 4000 BTU's of energy when you could of directly heated the water with the gas using only 3000... In the winter time you will never beat the cost or efficiency of directly using the same fuel source as your primary heat to heat your hot water.
On the other hand since the cost per BTU for natural gas, coal or wood is really low this will be cheaper than regular electric heater since the cost per BTU for electric is so high. There is always an efficiency loss strictly looking at the BTU's though.
In the summer since the cooling effect and de-humidification are desirable if you wanted to factor in the energy savings for less energy AC/Dehumidifier the efficiency goes off the charts over just the normal efficiency.
And that is how the spark spread was born https://www.google.com/search?client=firefox-b-1-d&q=spark+spreadLast time I calculated electricity and gas cost per BTU, electricity was 6x more expensive. It motivated me to run gas lines to the kitchen stove and dryer.
I've not forgotten, it's just not the most relevant factor. Usually most homes will only have one water heater. A heat pump tank installed in place of an 80% efficient gas storage hot water tank can easily beat that delivered efficiency in any well designed tight home that loses less than ~20% in the air circuit. The overall weighted efficiency would be (WeightedRoomUse * PrimaryHeat% * HouseLoss%) * (100% * WeightedElectricUse) Most gas homes today use storage water heaters that have abysmal efficiency, but have furnaces with very high efficiency, which is why it can conceivably come out ahead. Since we usually can't control nor care about the efficiency of the gas or the electricity produced at the primary generation or mining sites, this is as far as we care about here - optimizing efficiency and cost in the local setup we control.What you are forgetting is neither is the boiler or furnace producing your primary heat. Whether you are directly heating the water with gas or you are using a heat pump utilizing it from the primary heat there is an efficiency loss in the heat produced by gas.
The bottom line is if you are robbing heat from a primary heat source with a heat pump it can never beat the effciency/cost of directly heating the water with that fuel.
If you have a wood stove or a wood furnace, a heat pump is the cheapest, easiest way to scavenge that cheap wood heat for domestic hot water,
This is pretty much true in all cases where the standard electric dryer is vented. In a winter time unvented electric dryer comparison, it is not more efficient, but it uses less electricity directly. The overall efficiency of the heat pump dryer here is dependent on that same math we did for the heat pump hot water heater, but the circumstances are changed slightly. If you are heating the house with electricity as well, the efficiency is at best the same in both cases. If you are heating with an electric heat pump/mini split and not straight resistance heat, you are adding BTU load to that system, and added BTU load pushes those systems into a lower COP region, which increases the cost/BTU proportionally. Then you have to add back in the house energy losses between the heater and the dryer just like we did for the heat pump hot water heater. If you are heating with another fuel source, the efficiency metric is the same as we did before for the hot water heater, to come to a final efficiency % of the clothes dryer cycle.At the bare minimum HP dryer is twice as efficient as an electric dryer.
