All,
I have oil/heat pump/wood insert and have stated that I use wood when its below 45F and let the heat pump run above that temperature, and was asked how I derived that number. But that seemed like it should be an efficiency thread, not just a PM. So, let me try to explain my logic here.
I have a heat pump, with oil fired backup and a wood stove.
By default the thermostat runs the heat pump exclusively down to 50F, from 50F to 20F it looks at the oil burner, but hardly ever uses it, only on a defrost cycle, below 20F it is exclusively burning oil.
I have wondered at what point I should be burning my wood stove.
I have attempted to figure out what the actual beak even point is. I have also determined that its not possible to figure out. HAHA
The heat pump is rated by its HSPF, but that is a national average, over the actual winter. I have a trane XR-15. The HSPF (per spec) is, 8, maybe 7.7... I think, with my, non variable speed blower motor. But thats still a national average... so with some fudging numbers, lying, and speculation with the pretty solid spreadsheet here: (broken link removed) I figure that my HSPF is really 6.4 because of where I live. But since I will not be using it when its cold (I will use my wood stove) that changes everything.
Then guessing the costs,
$0.16/kwh (generating, transmission, tax, etc).
$175/cord
$3.50/gal oil (irrelevant since it doesn't get used)
And my efficiencies:
Oil 81% (per the tech who tunes it up)
Wood 71% per spec
I am guessing that the break even point between the cost of the heat pump and the cost of wood is somewhere around 45F. Above 46F i run the heat pump, 44-46F it is based on my mood. Below 44F I definitely am running the woodstove. That keeps the oil burner from running much (I use 30 gal/year). And the colder it is, the worse the heat pump's efficiency is. So, If i dont run the heat pump below 45F, the heat pump doesn't have the efficiency as if it was in Philadelphia. based on a national average low temperature map: http://2.bp.blogspot.com/_TRXN9Xw5s...AAT4/Mq9DJw_ZJXs/s1600/temp+christmas+eve.gif
it probably behaves more like it was in Atlanta, Ga... which makes it about 7.6, or there about.
So, for me (with local prices and efficiencies), the cost per MBTU is
wood: $11.20
Oil: $31.16
Heat pump (when operating above 45F): $21
Heat pump (if run all year): $25
So, why did i choose 45F, because the math shows that it probably isnt a good break even point?
I chose that because at 45F+ the fireplace puts out too much heat (A insert full of wood puts out more BTU than needed, even though it is cheaper $/btu, this case would result in wasted BTU) so the house gets too warm, also above 50F I have a hard time getting the draft moving in the right direction in the chimney (found that out the wrong way... twice). So that is how I determined that operating point.
I hope that cleared up the thought process. I was a bit rushed writing this, but the information should be valid.
Rick
$175/cord
Wood 71% per spec
wood: $11.20
Oil: $31.16
Rick
