hi all,
i have a weil mcclain ultra oil boiler with a beckett burner and an ergomax indirect water heater. in the past 80 days, the heat was never on so the boiler was only used to heat my hot water. i just had my oil tank filled up and it used 118 gallon of oil in the past 80 days. so that's roughly 1.47 gallon of oil used just to heat the water every day. that's very high, isn't it?
my questions are:
1. if i set the aquastat on the ergomax indirect water heater and the thermostat on the boiler down, would it be enough to receive the oil consumption significantly?
2. is it worth installing a heat pump electric water heater (e.g. GE geospring) to eliminate the usage of the boiler during non-heating season? i pay $0.17 per kwh
3. if i get a wood stove fireplace insert or a standalone wood stove to heat the home during winter along with the heat pump electric water heater, i could potentially get rid of my oil boiler and oil tank altogether, is it doable?
thanks,
m
my questions are:
thanks,
m
